06-21-2011, 01:55 PM | #6572 |
Can someone help me with this...I just installed the slave to the tranny. Now I'm trying to bleed it.I filled up the master with brake fluid, and presses the clutch in 6 times and held it. My clutch pedal stays in for some reason. Then I try to bleed it but very little or none Comes out. I followed the fsm instructions but its not working. Any help on how to do this have my the clutch pedal feel back? Thank you guys
06-21-2011, 02:27 PM | #6573 |
alright.....figured it out, and you were right, something was not connected right.....well actually wasn't connected at all. there were 2 wires going into the back of the fuse box under the drivers side of the dash, apparently they were for the voltage regulator and battery light. so they are now connected and everything is working good. thanks for the help.
06-21-2011, 02:42 PM | #6574 |
s13 steering wheel swap questions
so i just installed my NRG steering wheel but my turn signal cancelling options arent working, how can i make this work? i tried to align the tabs same as the OEM wheel, i have just a cheap adaprter hub for wheel, would that be what the problem is?
06-21-2011, 03:54 PM | #6575 |
^^ The turn cancel wont work any more no matter what. The tabs are too short on your hub to touch the cancels. Just have to get used to turning off the signals with your hand. I have a nrg short hub but haven't seen if it fixes the signals.
06-22-2011, 06:58 AM | #6578 |
06-22-2011, 08:51 AM | #6579 |
I have Zeals with Z32 shock mounts in the rear
I'm thinking of changing back to stock Zeal wants too much and tool long a wait for the shock mounts wondering if parts from a cheaper coilover will work. the rear Zeals use a 50 x 2.0mm diameter and pitch I have a set of Tein HEs and they are 52 x 2.0mm anybody got info on a set of rears from another company that fits? |
06-22-2011, 11:27 AM | #6580 |
No one has answered my three questions:
1) One of the terminals of the rear defogger got desoldered? Is nit possible to solder it back? 2)Does anyone has pics on this ignition "hotwiring" mod: Ignition mod I have been trying out(For external coil) : KA24ET / KA24DET Forum. It had pics at one time, but are no longer available. I have all necessary parts, just not where to do the connections 3) Are the center A/C vent frames easy to find, buy and install? The plastic frame on the center vent is missing and I know peole often remove the vents to install aftermarket gauges. |
06-22-2011, 12:16 PM | #6581 |
hey mew2senshi here is the video of the mod for your 2nd question
http://www.youtube.com/watch?v=44rSmOEGJDE If it doesn't help I can take pics of mine. |
06-22-2011, 01:11 PM | #6582 | |
mew2senshi, #1. I know those back window lines are metal or atleast conductive. There is a liquid that is conductive that electricians use. You can try that. Try searching for "rear window defog(or defrost) repair" with google, yahoo, etc... #3. Post a wtb thread in the WTB subforum. As far as installation, I don't have it in front of me but I don't think it would be too hard to install if many people are taking them out. |
06-22-2011, 01:39 PM | #6584 |
There is this: http://zilvia.net/f/chat/174916-identify-thread.html. Looks like oem s14 zenki navan rear valances to me.
06-24-2011, 11:56 AM | #6586 |
Trader Rating: (24)
Feedback Score: 24 reviews
I have a set of Ray's 50mm lugs with lock nuts on my subaru, and I lost one of the lock nuts (stupid stupid stupid). Not the keyed socket, the lug itself.
I've been googling all over trying to find a replacement and it seems like I'm SOL. Anyone know better? (Any 4 lug guys want a deal on a set of Rays minus one lock? lol). |
06-24-2011, 12:35 PM | #6589 |
what color and type are they?
I might be down if they are red and/or extended/open end.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
06-24-2011, 07:54 PM | #6592 | |
Trader Rating: (58)
Feedback Score: 58 reviews
Yellow pages.com
06-25-2011, 12:05 AM | #6594 | |
Trader Rating: (58)
[QUOTE=Origin;4114524]
Anywho to help you out: s14sr swap into s14 - Google Search There is a google link. The first thread should help you, but the rest is there. Google is your best resrouce.
06-25-2011, 01:32 AM | #6595 |
This is for the S14 people who have an aftermarket/fake K's spoiler:
I just picked up a fibreglass copy recently. It does not come with any mounting hardware built into it, but I was wonder if any of yours has any cracks in it from shaking/vibrations from driving over crappy roads or from shutting your trunk. |
06-25-2011, 01:39 AM | #6596 |
Does a o2 sensor cause your car to bog? I have a redtop sr20 and its bogging sounding like a subie. I'm guessing its going out so the ecu can't read it causing the car to run rich and lean sometimes. I just want to make sure before i go off buying a o2 sensor and that's not it. Thanks
06-25-2011, 02:32 PM | #6600 | |
