01-12-2009, 07:54 AM | #1 |
stiffing up s-chassis??
i have a 97 s14, 120k on it. the car chassis wise feels loose as s*it. the car just doesnt feel solid anymore, going over bumps and uneven roads everything feels loose and sloopy. i live in nyc and the roads suck that and add coilovers i guess it finally took a tole on my frame.
so what can i do to possibly stiffen back up the car? i was going to start with checking over all the bolts that attach the front/rear subframe to the car. i have nismo mounts and spl collors. i was going to get spl diff bushings because when i let off the cluth the rear chatters, also if i shift hard form first to second ill get wheel hop then the tires just spin. i was also thinking of a power brace for the front and possibly fender braces i heard that it does wonders.. any suggestions will help. i do not want to cage the car. so that is not an option. thanks
s14 kouki ka-t |
01-12-2009, 07:57 AM | #2 |
well from my experience wheel hop is induced by crappy suspension. what kind of coilovers are you running? how many miles are on them? do they need to be rebuilt?
and go with a urethane bushing kit. that will stiffn everything up real nice |
01-12-2009, 08:01 AM | #3 |
sus. setup:
megan streets ~8k on them sus. sway bars tien inner/outer tie rods spl collors nismo mounts battle version t/c rods
s14 kouki ka-t |
01-12-2009, 08:16 AM | #7 |
Luckily you have a 14 and dont have to do the column bushing like on a 13. That shit sucks - even with the motor out...
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
01-12-2009, 08:20 AM | #8 |
Your bet would be change the factory bushings most likely worn out and i would change those coils are nt the best HKs 111or sport,apex n1 or jic
The power brace would make the rear too stiff unless your using it for track use In Ny u need anything suspension thats adjustable cuz of those dam bumps, dips and potholes |
01-12-2009, 08:23 AM | #9 |
i think my dampering on the coils are to soft for the spring i turned them down to 7/5 i think ill raise them back to 17/15.
the power brace is for the front of the car so it would have no effect on the back. i have to jack up the car and see how much the subframe sags, i may have to do soild subframe bushings.. is it worth getting the energy sus. bushing kit? i heard its a pita to install..
s14 kouki ka-t |
01-12-2009, 09:22 AM | #11 | |
01-12-2009, 09:27 AM | #12 |
I wouldn't do the energy suspension bushings unless you were going to install grease fittings and cut a channel in them. They bind too easily. Spherical bearings work the best and you can upgrade to z32 rear uprights, i think the megan conversion piece is like $80... barter with them haha. You could do the chassis foam thing seen on FA also
Just talking about cars, one at a time Horsepower sells cars torque wins races -Shelby |
01-12-2009, 11:52 AM | #13 |
Trader Rating: (26)
Feedback Score: 26 reviews
if you have a lot of bumps and potholes, then you don't want to make any of the bushings that provide for/aft support(tension rods, traction rods, etc.) too stiff. for those, use urethane bushings.
replace the bushings that provide up/down support(rucas, rear toe rods, upper strut mounts, etc.) with spherical bearings. in all cases these are good. -Nismo power brace -strut tower braces -trunk brace -fender brraces good luck.
01-12-2009, 12:00 PM | #15 |
hmm..
my car is pretty stiff.. i have a cage. though. stance coils. megan tension/rucas (would the crappy rucas be the reason for my wheel hop??) i have a kaaz 2way. braces all over. GET SWAY BARS. tension rods and sway bars seriously made the biggest difference. I FELT A HUGE change i changed those out id really suggest just tons of braces. get a c-pillar lol they look cool :P and the rear strut bar i have no experience with the nismo power bar..but ive heard good things about it. and if you dont have AT LEAST subframe inserts DEF. get some |
01-12-2009, 02:43 PM | #16 |
You can get rid of a bit of that wheel hop with the only rear arm you didn't get... the traction rod
01-12-2009, 05:27 PM | #19 |
chassis foam in an area with salt (such as ny) is the worst thing you could possibly do. Read up on some old hot rods or european cars that had factory foam. The only rust spots were where the foam was.
01-13-2009, 06:19 PM | #22 | ||
they do stiffen up the car quite a bit but I don't really like the way the suspension works after spherical bushings and quality joints is what I plan to do down the line. |
01-13-2009, 10:02 PM | #23 |
Trader Rating: (31)
Feedback Score: 31 reviews
Handi-Foam.
Thats the RIGHT STUFF. $49.88+ ship for a kit to do maybe the rockers and a tad more. DO NOT USE SPRAY Insulation foam. Ordering mine this week.Gonna do the rockers and Try to figure out a way to do the Frame rails.Not sure how except drilling holes.
z-tERty-2 |
01-14-2009, 02:17 AM | #27 |
I have all that crap for my kouki and what made the biggest difference was
Coilovers ES Bushings for EVERYTHING (besides what you replace with pillowballs) Power Brace Shakitto Plates/DC front strut bar Do-Luck Rear Cross Bar In that order... I have more but that is what I noticed the most. |
01-14-2009, 06:05 AM | #28 |
thanks for all the info im going to do the power brace, arms , diff bushings, strut bars, and the other bushings.
but if i do all the arms will it not be pointless to get the energy sus. bushing kit as most of the arms will replace the use for bushings? and the foam seems like a good idea, but how much weight does that add on the car?
s14 kouki ka-t |
01-14-2009, 08:15 AM | #30 |
Polyurethane bushings suck, I had whiteline ones in all my arms all around, they suck. Get spherical bearings, car feels softer plus no bind now hah.... better response and tightness yet soft not nerv racking.
