Old 05-17-2009, 05:31 PM   #1
kissritz
kissritz's Avatar
kissritz is a jewel in the roughkissritz is a jewel in the roughkissritz is a jewel in the roughkissritz is a jewel in the roughkissritz is a jewel in the roughkissritz is a jewel in the roughkissritz is a jewel in the roughkissritz is a jewel in the rough
Send a message via AIM to kissritz
Ka24de wont fire! Plz help
So ive been reading tons of threads and replaced a shit load of things, and still doing the same thing. its turning over but not firing, ived changed the spark plugs, distributor, ran a compression test, maf sensor, tps sensor, fuel pump,fuel filter, fuel pump fuse, checked gounds and harness, tried removing the temp sensor to see if it would fire, used starting fluid... still Nothing!! any suggestions? im going to change the Ecu and Coil tommorow, see what it does. Thanks
DORI_XXX
kissritz is offline   Reply With Quote
