Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Interior & Exterior
Old 05-26-2011, 06:16 PM   #1
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
S13 Center Vent Angled Triple 52mm Gauge Plates
S13 Center Vent Angled Triple 52mm Gauge Plates: $75 shipped
Please inquire if you would like non-angled 52mm or 60mm
NOTE: Please allow up to a week for the fabrication. These are made to order!
  • Main plate is CNC'd from 1/8" aluminum
  • Inside radius of the gauge openings are beveled so the gauge will drop in when angled
  • ABS angled rings are prepped to remove all casting nubs
  • ABS angled rings are trued on the bottom side as they do not come 100% flat
  • Main plate and rings are texture coated for OEM look
  • Painted with high quality SEM Satin Black
  • Includes aluminum mounting brackets that can be modified to fit your particular gauge(see pics below)
  • The mounts can also be modified to make a rock solid mounting system for the dash(see pics below)
Close up of texture coat and SEM paint:
Rings are 100% flat on the bottom:
Example of modified bracket to fit a specific gauge:
Example of how you could drill and tap the modified brackets and insert threaded rod into it. Then simply use some aluminum or other material to make a "washer" to span the back of the vent opening. Finally some simple wing nuts and you can easily attach it all from the back. This will also help really suck the plate into the opening of the dash.
UPDATE:
As I have mentioned in this thread, I can have any combination of gauge placements fabricated. For example: Chase from Chase Bays wanted a plate with one 52mm at the end and that was it. No problem! I can also do triple 60mm non-angled, double 52mm with vent angled or non-angled, any # of 52mm or 60mm from 1-3 or any combination of. Note: these are all special order so allow up to 4 weeks for delivery. Price is the same($75 shipped) for all angled plates and $40 shipped for non-angled. NOTE: 60mm cannot be angled in the standard fashion. All pieces are finished just like everything else: textured and painted with high quality satin black to best match the OEM finish of your S13.
Some Examples:
Triple 60mm:
Dual 52mm with vent:
Dual 52mm angled with vent:
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline
Old 05-26-2011, 06:29 PM   #2
ka24det92
ka24det92 is an unknown quantity at this point
do you make a dual gauge holder
ka24det92 is offline
Old 05-26-2011, 07:07 PM   #3
Broadfield
Broadfield's Avatar
I do not because there is no demand for them. However, I can have one CNC'd if you would like. It would probably be a month or more though before I put in another order to the metal shop.
I do have a dual 52mm holder, but it has the slots in between for the vent to still function somewhat as a vent. You could still do the angled rings on it if you wanted. Otherwise like I said above, if you want the dual holder without the vent openings, then I would have to special order it the next time I place an order.
Thanks,
Toby
My Portfolio
Please Share
Check Out My Builds
Old 05-26-2011, 07:11 PM   #4
pandaroo
pandaroo's Avatar
pandaroo is an unknown quantity at this point
this is rad. just gotta find me another guage to stick in there lol.
89 2tone coupe
2jzgte swap in progress
pandaroo is offline
Old 05-26-2011, 07:52 PM   #5
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
How much if I only wanted the rings and brackets to angle the gauges.. I already have vent pod holder very similar.
MORE BACON STRIPS
negrosx13 is offline
Old 05-26-2011, 08:52 PM   #6
Ramonesfreak2010
Ramonesfreak2010's Avatar
Ramonesfreak2010 is an unknown quantity at this point
I just need the brackets. I bought the gauge plate a few months back.
Ramonesfreak2010 is offline
Old 05-26-2011, 09:05 PM   #7
Broadfield
Broadfield's Avatar
Sorry, I do not sell them separately. However, you can get some from Summit.
I cannot sell the brackets separately as they come with the angled rings.
My Portfolio
Please Share
Check Out My Builds
Old 05-27-2011, 02:05 AM   #8
cookie_monster
cookie_monster is an unknown quantity at this point
Dammm I so want this!!! Maybe when i get paid ill get this if you still have a set left.
cookie_monster is offline
Old 05-27-2011, 04:56 AM   #9
va240dude
va240dude's Avatar
Trader Rating: (161)
va240dude is an unknown quantity at this point
Feedback Score: 161 reviews
Nice job Toby, glad somebody thought of making this a complete kit! I might have to pick one of these up from you soon! Bump for quality work.
180SXオタクだ!
va240dude is offline
Old 05-27-2011, 05:14 AM   #10
CC200SX
CC200SX's Avatar
CC200SX will become famous soon enoughCC200SX will become famous soon enoughCC200SX will become famous soon enough
Excelent kit, top job!
Post to Portugal?
CC200SX is offline
Old 05-27-2011, 05:14 AM   #11
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
not that i need to, but i can vouch for toby's work. it is above and beyond ANYTHING i've ever seen in 7 years of being an automotive enthusiast. i'm debating starting an s13 overhaul/restoration for a dd...if i do i'll be taking one of these.
sidewaysil80 is offline
Old 05-27-2011, 09:29 AM   #12
cjmirabal1
cjmirabal1's Avatar
cjmirabal1 is an unknown quantity at this point
NICE!!!! an angled dual pod with vents (florida heat!! need ac!)
would be amazing!!!
cjmirabal1 is offline
Old 05-27-2011, 11:33 AM   #13
Psycho 240 Freak
Psycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-known
Nice, I've been wanting these for a while now. I've purchased from you before, but it's been a while. You do paypal right? Can you send me your paypal info or whichever payment method you'd like?
Psycho 240 Freak is offline
Old 05-27-2011, 12:15 PM   #14
wisdom01
wisdom01 is on a distinguished road
Great job on this kit. they look sweet!
wisdom01 is offline
Old 05-27-2011, 03:13 PM   #15
Lucas180
Lucas180 is an unknown quantity at this point
How do i buy a set ?
Lucas180 is offline
Old 05-27-2011, 06:39 PM   #16
Broadfield
Broadfield's Avatar
I will always have them available
Thanks Matt!
Post to Portugal?
Add $10
Thanks Tim, I appreciate the feedback.
I prefer Paypal: [email protected]
Please enter in the comments box what the payment is for.
Thanks guys!
My Portfolio
Please Share
Check Out My Builds
Old 05-28-2011, 03:55 AM   #17
Psycho 240 Freak
Sweet, payment sent.
Old 05-28-2011, 03:38 PM   #18
Broadfield
Broadfield's Avatar
Thanks man, I'll get it shipped out next week. You will receive a tracking # from Paypal once it ships.
Thanks,
Toby
My Portfolio
Please Share
Check Out My Builds
Old 05-28-2011, 03:41 PM   #19
zspeedrft
zspeedrft's Avatar
Trader Rating: (54)
zspeedrft is an unknown quantity at this point
Feedback Score: 54 reviews
are these rhd friendly??
zspeedrft is offline
Old 05-28-2011, 03:52 PM   #20
Broadfield
Broadfield's Avatar
Yep! The main plate would simply be rotated 180 degrees compared to mounting it in a LHD.
My Portfolio
Please Share
Check Out My Builds
Old 05-28-2011, 09:31 PM   #21
feadz
feadz is an unknown quantity at this point
How much for a non-angled triple 60mm? I need to fit some Defi BF's.
feadz is offline
Old 05-28-2011, 10:23 PM   #22
Broadfield
Broadfield's Avatar
It would be $40 shipped and would have the same textured finish.
Thanks,
Toby
My Portfolio
Please Share
Check Out My Builds
Old 05-29-2011, 06:28 PM   #23
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
fawkk... I wants...
BiG MiKE86 is offline
Old 05-29-2011, 06:44 PM   #24
Jtuned_andy
Jtuned_andy's Avatar
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Are there 60mm angle spacers available?
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline
Old 05-29-2011, 10:53 PM   #25
Broadfield
Broadfield's Avatar
There is not.... it's not really possible physically without going to full molded fabrication. Even then it would be too tight for my liking.
My Portfolio
Please Share
Check Out My Builds
Old 05-30-2011, 01:47 AM   #26
Jonathong
Jonathong's Avatar
Jonathong is an unknown quantity at this point
damn if only there was something like this for the s14! I really need a setup like this somewhere in the car
Jonathong is offline
Old 05-30-2011, 02:28 AM   #27
RickyS13.
RickyS13.'s Avatar
RickyS13. is an unknown quantity at this point
im really gonna be getting one of these when my gauges come in!!
RickyS13. is offline
Old 05-30-2011, 03:01 AM   #28
tabasco122
tabasco122 is an unknown quantity at this point
do you mount\glue the rings on the plate, or do they have to be assembled? because i attempted to do this with the autometer rings after seeing your car in the magazine a few months ago, but i failed at getting them all straight, they were all different angles lol.
tabasco122 is offline
Old 05-30-2011, 07:41 AM   #29
ka24det92
Thanks,
Toby
that's what im looking for how much is the one with the vents
Old 05-30-2011, 07:50 AM   #30
CC200SX
CC200SX's Avatar
Add $10
Hi can you ad to the kit 2 more angle spacers, because i have 5 gauges?
CC200SX is offline
angled gauges, broadfield, s13 center vent gauge
