03-25-2018, 07:03 AM | #21691 | |
03-25-2018, 08:50 AM | #21692 | ||||
His next mod will probably be sticker bombing it or trailer wheels.
Tuners are big bullies |
03-25-2018, 04:16 PM | #21693 |
Except when they're not adjustable, like the Tial or HKS. And I can tell you from experience that the HKS will open with only a few PSI in the pipes, whereas the Tial will not open with anything less than 10 PSI.
03-25-2018, 06:43 PM | #21695 |
Are these real or fake bride gias seats? Here' the ad:
"Authentic Bride GIAS low max carbon kevlar seats $1,200 Walnut, CA selling 1 mint condition authentic and reclinable seat. retail is about 2.2k a piece. Was going to put these in but decided to go with FRS seats and save money instead. seat is almost like brand new Located in West Covina |
03-25-2018, 07:04 PM | #21696 | |
Sent from my SM-G950U using Tapatalk |
03-25-2018, 07:52 PM | #21697 |
They're selling $4400 worth of seats for $1200. What do you think?
Two expression generally hold true in life: -You get what you pay for -If it's too good to be true, it probably is Based on the price, I think the seats are fake. |
03-26-2018, 11:25 PM | #21699 |
Is 9k racing in whittier, Ca a legit shop? they are offering the gias too for 1800 a seat out the door for brand new.
" Country of Origin: Japan Bride seats are authentic and comes with serial # with matching certificates. " |
03-26-2018, 11:55 PM | #21700 |
That's pretty close to retail. If you're willing to spend that much, just get one from an authorized Bride distributor. There are so many fakes out there, that I wouldn't trust anyone else.
http://bride-jp.com/en/distributor/ |
03-27-2018, 02:02 AM | #21701 | |
Trader Rating: (31)
Feedback Score: 31 reviews
Sent from my SM-G955U using Tapatalk |
03-27-2018, 01:14 PM | #21702 |
Ok, so I picked up an SARD top feed fuel rail for my retop SR. It seems like SARD makes a top feed injector for a CA but all I see for SR is side feed. Does anyone know what injector would be compatible with this rail? I can’t seem to find a definite answer for SR anywhere. Thanks in advance!
Sent from my iPhone using Tapatalk |
03-27-2018, 01:52 PM | #21703 |
03-28-2018, 12:36 PM | #21704 |
My SR20 with a stock trans has 400whp and a twin disc. From what I've been reading my trans should have blown up by now.. I did a handful of drift events last summer with more to come this summer. Should I be worried?
03-31-2018, 12:01 PM | #21705 |
Trader Rating: (18)
Feedback Score: 18 reviews
Question about Nismo subframe bushings on a S14...
I ordered some and am gonna put them in once they arrive. Does anyone that has done this in a s14 know if you have to cut the inner sleeve out when you put these in? I am assuming you do. |
03-31-2018, 04:31 PM | #21707 |
I'd only worry about it untill it happen but I would have a z32 or z33 tranny and adapter stuff ready for when it does it happen so it's not alot of down time
03-31-2018, 10:24 PM | #21709 |
Trader Rating: (31)
If anyone here has Nissan FAST, would you please be able to look up p/n: 62042-65f00
I cannot find what car this retainer goes to. I've searched up and down with no return. The s14 zenki retainer is 62040-65f00, however I want to make sure what this is before I try and sell it. Thanks in advance! Sent from my SM-G955U using Tapatalk |
04-01-2018, 09:22 AM | #21710 |
Datascan is throwing code 34, wiring shows 550k ohm from connector to ecu so that is okay, grounding wiring seems good too, I cant see the sensor itself yet, but how likely the sensor itself is broken? I wouldnt want to buy a new sensor since they cost a shitload and if its for nothing...
Anyone here gotten code 34 and fixed it? I read that a lot of people replaced the sensor but code remained. Also how hard is it to replace the sensor? Just take off intake and can I reach it then? |
04-01-2018, 11:41 AM | #21711 | |
04-01-2018, 01:43 PM | #21712 |
04-01-2018, 06:46 PM | #21713 |
You can get a knock sensor for about $30 on rockauto. Or even a $7 one off eBay will work good enough to clear the code.
04-01-2018, 11:36 PM | #21714 |
S14 coilover's dampening setting.
What's recommended for the S-chassis as far as front to rear bias on a street car? Im trying to compensate for the car's 'twitchiness' (slight up/down oscillating), but have read conflicting information. <- Different chassis (ff/awd) Details on specs if needed. S14 Stance XR1 8k/6k @ 3"- 4" drop. 40 series rubber (no stretch) Daily driver (HWY) P.S I do plan on contacting Stance for recomendations, however I would like to know abit more about our chassis Dynamics/ personal experiences. Last edited by [240sx]; 04-02-2018 at 11:15 AM.. |
04-01-2018, 11:43 PM | #21715 |
^ Not sure what happened to my post after an minor edit? I'll try and correct it but if anyone got the email notification with the details on my original post, I'd appreciate it if were reposted.
Sent from my SM-G930P using Tapatalk |
04-02-2018, 12:29 AM | #21716 |
My Stance GR+ 8/6k rode the exact same way no matter how I adjusted the shocks. Maybe it's just the spring rate. I replaced them with a set of HKS Hipermax which rode MUCH smoother. Not sure of the spring rate on those, but I assume they weren't as high.
04-02-2018, 11:14 AM | #21717 | |
Commuted to work today, and noticed its really prevalent in semi low speeds. I was driving at a consistent 50 mph in traffic when I felt the Seesaw-esk sensation. Last edited by [240sx]; 04-02-2018 at 04:34 PM.. |
04-02-2018, 05:03 PM | #21720 |
Ok so I'm doing the 300zx rear e brake, hub, and caliper swap on my s13 and everything was going fine until my rotor decided it doesn't wanna going on. And on the drivers side both rotors fit perfectly but on the passenger side it just won't slide in how it should. Any ideas on what can be going with it?
