Old 10-02-2023, 09:46 PM   #1
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
KA24E vs DE exhaust manifold
I'm well aware that the upper exhaust manifold is completely different between the SOHC and DOHC. But what about the lower pipe (up to the last cat)? Should I be able to bolt a lower pipe from an E to a DE?
Crazyced is offline   Reply With Quote
Old 10-10-2023, 07:18 AM   #2
AKADriver
AKADriver's Avatar
The pipes have different part numbers but the heat shields, gaskets, etc. are all the same, I would bet on it being compatible, at least S13 to S13. Won't work with the S14 precat stuff obv
