Old 07-20-2016, 05:25 PM   #1
DylanKouki96
DylanKouki96 is an unknown quantity at this point
s13 won't crank, wont start (auto to manual conversion)
Im having issues starting up my 1990 240sx hatch. Was converted to manual, but still has auto ecu because previous owner never swapped it out. I try to turn it on, but it doesnt crank nor startup. The battery was just recharged and checked for any issues. I replaced 3 30a fuses and the car turned on but slowly wanted to die out unless i would press on the gas. Im not sure what is causing the problem. But ive replaced the fuses twice, and battery is good. And help? Im being told it might be the starter, alternator or wiring harness. Not sure what to do at this moment.
DylanKouki96 is offline   Reply With Quote
Old 08-03-2016, 06:27 AM   #2
dustin_rps13
dustin_rps13 is an unknown quantity at this point
Did you make sure to bypass the nuetral safety switch?
I think the ECU might make a difference, not 100% on that, it's been forever since I've had to do a manual conversion on one of these. Maybe someone else can chime in on that.
I HAVE A BEARD, THEREFORE....F@#% YOU!
dustin_rps13 is offline   Reply With Quote
Old 08-04-2016, 01:44 AM   #3
240trooper
240trooper's Avatar
240trooper is a well-known jackass
Send a message via AIM to 240trooper Send a message via Yahoo to 240trooper
Don't know much but I do know you can use either manual or auto ecu and the car will run and drive properly.
2.7L
240trooper is offline   Reply With Quote
