09-11-2014, 11:16 PM | #1 |
440HP RB25, caged, RPF1, Garrett, TIAL, Quality Build.
SOLD
YT]TPesozgU98s&feature=youtu.be[/YT] Originally purchased in January 2013 from a Zilvia member who was very honest and up front about everything. I genuinely appreciated that so I am doing the same. Please PM me any questions/requests for pictures/videos and I will gladly help you out. Enjoy! The Car: 1989 Nissan 240sx Coupe Factory two-tone paint "Seafoam" (silver/green) 172,000 Miles on chassis *CLEAN TITLE. *PINK SLIP IN HAND. *REGISTERED UNTIL JAN 2015 Powerplant: The engine was professionally built and installed by Alex and Adrian at Vildini Motorsport in 2009. The bottom end is built with CP forged pistons and ACL race bearings. The exterior is the only place that needs attention. I personally think the imperfections add character but you could say it needs paint. Few spots of surface rust around the windshield and sunroof. There are a few dings and stuff as well. Typical stuff for a 25 year old car. In December 2013, the new Garrett turbo, all new intercooler piping, injectors, fuel rail, and tune were completed by Bardabe Performance. Car was dyno'd and is currently putting down 440HP to the wheels. Car weighs less than 3000lbs. I have all of the receipts/paperwork for the work that was done. Tons of quality parts. Engine and Drivetrain Specifics: RB25DET Garrett GTX3076R turbo Greddy Fuel Rail Tomei Fuel Pressure regulator Injector Dynamics 1000CC injectors Modified stock exhaust manifold for TIAL external wastegate Custom fabricated 3" aluminum piping for intercooler with new couplers/t-bolts CP forged pistons ACL race bearings Metal head gasket McKinney motor mounts with polyurethane bushings. Custom driveshaft Greddy style intake manifold Z32 MAF Spec Stage 3 clutch Greddy Front Mount intercooler. Painted matte black heat resistant paint. TIAL BOV TIAL External Wastegate w/20LB spring and blast pipe pointed to ground running right along turbo/steering column Trust air filter Custom 3 inch straight through exhaust from the turbo back, tucked up as high as possible to maximize ground clearance "Stock looking" straight flow muffler with two 3" tips. Painted with matte heat resistant paint. Mishimoto radiator w/ Flexalite High-flow fans sealed to radiator. VMS Motorsports vented oil catch can Aluminum coolant overflow reservoir New Optima Red Top (2014) battery relocated to trunk Apexi Power FC commander Powder coated valve covers (wrinkle red) Power coated engine block (gloss black) Nismo 1.5 way LSD with 4.3 final drive Suspension, Chassis and Brakes: Apexi EXV coilovers Battle Version Rear Traction Rods Battle Version Rear Toe Arms Battle Version Front Tension Rods Battle Version Rear Upper Control Arms Cusco front strut tower brace Cusco rear triangle strut tower brace Enkei RPF1 rims: 17x9 +22 fronts, BF Goodrich G Force Sport front tires, 225/45/17 90% tread. 17x10 +18 rears, Yokohama S Drive rear tires, 235/45/17 90% tread. 5 lug conversion Rebuilt Z32 TT front calipers (powder coated red) Drilled and slotted front rotors S14 rear rotors Stainless steel braided brake lines Stainless steel power steering high pressure line StopTech rear brake pads (installed 8/2014) Hawk Performance front brake pads (installed 8/2014) Silvia trunk lock and badge on rear. Interior: Cracked dash typical of 240's Nardi 350mm Deep Corn steering wheel NRG quick release hub Tomei shift knob Autometer oil temp, voltage, and boost gauge in central vent area Quick release parking brake Sparco Torino driver seat S14 passenger seat. Sparco harness tethered to cage Autopower 4 point cage. Fire extinguisher mounted on cage. LED dome and trunk lights. DYNAMAT sound deadening mat entire trunk. Definitely gets a lot of looks/thumbs up and is an absolute V8 hunter/destroyer. The car is located in San Jose, CA. I am sure I left off a couple things I've upgraded so if you have any questions, please post/PM me! If you are in the bay area, I welcome you to come see it in person, I can always meet you halfway Asking a modest $12,000. Cash is king. ENJOY IN HD! Exterior Walkaround: Interior: Start up: Engine/exhaust Idle: Fly By: On Ramp: Dyno Pull: Last edited by Nizmology; 01-04-2015 at 11:33 AM.. Reason: Ad description/videos/Price |
