04-03-2016, 08:43 AM | #19531 |
Alright guys, ive tried searching this, but nobody in any thread that ive seen the same problem in, has had an answer..
I have a z32 maf and according to the 300zx fsm, key on engine off, the maf should have a voltage of .8 - 1.5 volts. Mine however is showing .48 volts, according to NDS. At idle my voltage is about 1.25, which is within spec. What is the reason for having to be at the voltage the fsm states, in an engine off state? And what might be the symptoms of not getting the correct voltage with engine off, but getting the correct voltage when engine is on? |
04-03-2016, 12:51 PM | #19532 |
Loose Door / Window
Couple door/window issues I could use some help with...
- Driver's side door unlatches too easily. Shuts fine (save for 2nd issue below) and latches, but when opening the door it's unlatched before the handle is even halfway pulled. Seems too easy, and I could see it getting worse over time. I noticed the black plastic wrapping the door striker is cracked and worn down. Is it a reasonable assumption that replacing that will fix this, or should I look elsewhere? - Window seems loose in the driver's side door. When shutting the door the window wobbles somewhat worryingly, feel like I might eventually break it. This is just when closing the door, once shut it's as stable as one would expect. I can take the door apart and try to find loose bolts, but appreciate tips on what I should be looking for, or if I might need to replace a part to tighten things up. Thanks |
04-04-2016, 06:56 PM | #19533 | |
04-04-2016, 08:35 PM | #19534 | |
04-04-2016, 08:53 PM | #19535 |
wasent there someone on here making replica g grow aero at one time? anyone know who it was? thanks
http://front-street-drift-club.tumblr.com/ |
04-04-2016, 11:42 PM | #19536 |
having a few problems with my car and was wondering if anyone could help me out. at startup, its hard to start the car. i have to give it gas or else it will die out. also, my idle is kind of "lumpy" and its pretty rough. idk if its misfiring because it doesnt sound like the typical misfiring sound. usually when putting it in neutral, the idle will drop down and almost dies but never does. sometimes it will stay low until i give it gas then it will idle back at 750-800. sometimes it will idle fine then all of a sudden it will start to idle low. ive cleaned the maf, got new spark plugs, and new cap and rotor and all seemed to not help much at all.
Instagram:@juhd_ |
04-05-2016, 06:25 AM | #19537 | |
04-05-2016, 02:45 PM | #19538 | |
If that doesn't fix it, It would have to be your sensor or wiring (ground). |
04-05-2016, 04:17 PM | #19539 |
Thanks, i ordered an after market one by dorman so it should be getting here soon, i was just worried that if i did buy one from nissan it wouldnt line up correctly with the bolts on the firewall, but problem solved lol, thanks
04-05-2016, 07:25 PM | #19540 | |||
Trader Rating: (58)
Feedback Score: 58 reviews
http://tech.240sxone.com/FSM/1993%20...20CA,US/HA.pdf Two quick ones though: Take a wire from the + battery post, direct to the compressor. Does cold air blow? Now you're got a switch issue. Does the light in the dash illuminate when you press it for AC? Switch issue or low freon? If you have 12v at the compressor, you have a bad clutch on the compressor Quote:
Id' not worry about it truthfully if it's low at KOEO Quote:
04-05-2016, 09:00 PM | #19541 |
Trader Rating: (58)
Does anyone know who was the manufacturer for RSR brand exhausts?
04-05-2016, 11:13 PM | #19542 | |
BUT, sometimes its the complete opposite. At a stop, ill let go of the break pedal and ifrs will go full lean and idle will surge and misfire.. Until i press the break pedal. And then afrs will go stoich and idle rpm will level out. Like before though, sometimes afrs will go bad to stoich, but ilde surge and misfire will still be there. |
04-06-2016, 03:11 AM | #19543 | |
http://www.amazon.com/Taylor-Cable-7...+plug+wire+set You can look up blue or red too, but any set of wires that adds a legit 3hp is OK in my book. There are also wires by OBXR and VSR Racing(sp) that work too
04-06-2016, 10:10 AM | #19544 | |
Instagram:@juhd_ |
04-06-2016, 05:57 PM | #19545 |
So I've really been looking into the yashio factory consult v2, but I'm concerned about the coolant temp sensor capability. It pulls the temp from the ecu coolant temp sensor rather than a separate one as the first version did. Is this accurate enough? I know the temp sensor for the gauge is crap, but how accurate is the ecu one? Thanks in advance
Sent from my SM-N920V using Tapatalk
insta: @wanganz.jp |
04-06-2016, 08:14 PM | #19546 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
04-06-2016, 08:16 PM | #19547 | |
04-06-2016, 09:50 PM | #19548 |
I was curious about this myself and did some data-logging to investigate. Surprisingly, the temperature gauge in the cluster is actually a good indication of when things are getting too hot. The middle of the gauge represents normal operating temperature and its upper mark, what I like to call "full-hot", represents 220 F, which is right about the absolute maximum that water temps should be allowed to reach before possibly causing damage.
04-07-2016, 04:26 AM | #19549 | |
04-07-2016, 08:31 AM | #19550 |
Plz help s13 sr20det into s14 won't start just cranks ,new fuel pump new ignitor chip c.a.s has been reset getting spark buddy helped yesterday and said injectors were clicking ecu light powers on I believe all my grounds are connected
04-07-2016, 09:32 AM | #19551 |
Yo Batgang, you don't need to go around asking the same question in any thread you see fit. Give it some time and someone might answer your question.
To your issue, injector clicking is one thing, but are they spraying the fuel properly?
04-07-2016, 10:10 AM | #19552 | |
You need to slow down with the parts swapping and do a real diagnostics. Running Stock ECU? New used or new new Ignitor? Have you pulled each injector one at a time to test for spray? I recently weren't through a whole no-start fuck my life project when I switched from a stock ECU to a MS2. Turned out - Bad Ignitor despite two coils getting juice. Bad CAS- it just was not reading right Bad Fuel Filter - Oh long winters Bad Injector - was only dribbling fuel. Got that all fixed, retuned and blew up my TOB. |
04-07-2016, 11:06 AM | #19553 |
Sorry bout that ,but ecu stock, new new ignitor,new new fuel filter,and when it warns back up going to try taking one injector out at a time to see if it's spraying.thanks for the info will update soon about injectors
04-07-2016, 01:26 PM | #19555 |
I am having trouble locating the harness that connects to the Evap canister on the 1996 OBDII 240sx. I have a bad plug so i have the code po446, Im trying to pass emissions unfort. so i need it. Anyone have this or where i could possibly find this. Willing to pay
My facebook post is here : https://www.facebook.com/groups/1015...59986621169290 |
04-07-2016, 08:37 PM | #19558 |
04-07-2016, 09:23 PM | #19559 | |
