Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA
USA Talk to others in your region.
Old 12-30-2013, 04:49 AM   #1
miken987567
miken987567 is an unknown quantity at this point
Exclamation Adaptronic select plug sr20det NEED HELP "PLEASE"
Anyone ever master the Adaptronic select plug, "engine management" system? I'm using it on my sr20det but I'm currently having trouble setting it, any advice?
Anyone that would be so kind to make me a basemap if I tell them my specs, this is my daily driver I need the car very bad!
No ones in Florida know how to work this thing!!!! Please help
Message me on here or email: [email protected]
miken987567 is offline   Reply With Quote
Old 12-30-2013, 08:53 AM   #2
RB2.5
RB2.5 is an unknown quantity at this point
What exactly do you need help with? Did you get a base map from Adaptronic? Those things are extremely easy to tune.
RB2.5 is offline   Reply With Quote
Old 12-30-2013, 11:40 AM   #3
miken987567
I did download the base map so the car starts and stumbles while driving, I'm having an issue setting everything up for my fully built sr. In other words I wanted to see if I give all my Info to somone if they could make me a pretty close map, so I'm atleast able to drive the car without blowing black smoke out of my tail pipe. Fuel adjustments and what's what. I just got the system. So I dot know anything about it besides the basics
Old 12-30-2013, 12:22 PM   #4
RB2.5
You're probably going to have to email Adaptronic direct, as you might have a problem with your mechanical setup( IE you have it set to external map sensor, but you're using the internal 4 bar map sensor). I would take a datalog and send it with your ecu file to them. They have great tech support.
Old 12-30-2013, 12:57 PM   #5
miken987567
Ok will do man thank you very much
