Old 01-29-2013, 10:35 PM   #1
todd5854
todd5854 is an unknown quantity at this point
s13 cruise control acting up
Stock KA... swapped it manual, and there was a relay I was told to remove and jumper to get the cruise control to work again. I found 5 different guides, and they all said to jumper the same one, so that's what I did. Worked fine for the first two months
Now, when I turn it on, lets say im doing 70... if i press "set" it drops to 65. and maintains it for a little while. If I press and hold accel, no matter what it will accelerate to 70 and no more. if I hold it until it reaches 70 and then let go, it still drops to 65.
I checked where it connects to the throttle body, there is a nice tight cable connected..
My first thought is the vacuum pump / diaphragm is going bad. does that borrow vacuum from the cars system? Or does it use its own? hopefully its own....
todd5854 is offline   Reply With Quote
Old 01-30-2013, 11:54 AM   #2
todd5854
anyone...?
Old 01-30-2013, 12:15 PM   #3
Mikester
Mikester's Avatar
258 Auto Speed Control Device :: Body Electrical :: Genuine Nissan Parts :: 240SX Parts (S13) 1989-1994 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
Old 01-31-2013, 10:04 AM   #4
todd5854
So you think I need the actual control module? I thought for sure it was that vacuum diaphragm, or maybe its pump
