11-12-2011, 05:51 PM | #1 |
92 Nissan 240SX w/180SX Aero, Built SR20, & Suspension Mods
I am selling my 1992 Nissan 240SX that I have owned for over 10 years.
The car has over 150,000 miles on the body that has no rust because it was never driven in the winter and less than 10,000 miles on a built SR20DET S13 blacktop. It made 330 rwhp and 279 ft-lbs of torque at 16 PSI of boost on the dyno. Issues: -Small chip in windshield -Small chips in the paint -Speedometer no longer works -No A/C I am asking for $OLD Contact me at 216.235.7972, PM me, or email me at [email protected] Below is the mod list and pictures: ENGINE: (s13 SR20DET blacktop) Garrett GT28RS turbo (Disco Potato) 550cc Tomei Injectors Walbro fuel pump Wiesco Pistons K1 Technology Rods HKS 256/264 Camshafts Supertech Valve springs/retainers Tomei Rocker Arm Stoppers ARP Studs Apexi Headgasket (1.2mm) Moroso Oil Pan New OEM Oil pump New OEM Timing chain kit NEW OEM Water pump New OEM Valve guide Block cleaned and decked Megan Manifold (Ceramic coated & reinforced) Greddy Intercooler Greddy Oil filter relocation kit Mocal Oil cooler Custom oil catch can Koyo Radiator FAL dual Fans DIF Fan controller Samco hoses Nismo Thermostat Circuit Sport Overflow tank SUSPENSION/BRAKES/DRIVETRAIN: KW V3 Coilovers Cusco upper camber plates Kazama tension rods Kazama rear camber arms Kazama rear toe links Kazama rear traction arms Tien inner/outer tie rods Suspension Technique sway bars (front/rear) Greddy Strut bars (front/rear) Nagisa Auto fender braces Z32 brake calipers front & rear Z32 master cylinder (1") Z32 E-brake assembly Hawk HP+ pads (front and rear) DBA 4000 slotted rotors (front and rear) S15 HLSD ACT 6 Puck Clutch ACT Streetlite lightweight flywheel ELECTRICAL: Enthalpy flashed ECU Braille 11lbs battery Buddy Club grounding/voltage regulator kit AEM Tru-boost controller gauge AEM UEGO wide band gauge AEM water temp gauge AEM Oil pressure gauge EXTERIOR: OEM 180sx front bumper & lights OEM 180SX rear bumper extensions OEM 180SX side skirts OEM 180SX rear wing OEM 180SX rear lights 17x9 +15 black 5zigen FNs (front) 17x10 +25 black 5zigen FNs (rear) Nitto NT05 tires (235/40/17 front & 255/40/17 rear) Rolled/pulled fenders INTERIOR: Sparco steering wheel Sparco Hub Tekniq Autosport quick release hub Sparco Road pedals S15 front seats s14 manual seat belts Last edited by Ohio_S13; 11-20-2011 at 09:34 PM.. |
