Old 06-27-2018, 04:51 AM   #21931
I'm Redline
I'm Redline's Avatar
Oval mufflers are better for quieting drone down, but a mid mounted resonator helps a lot. Remember, you have pretty much straight pipe from header back to the end where the muffler is so all you have under the car is straight pipe. Adding the resonator, or a middle muffler will quiet things down a lot. I thought it a great idea to make a lightweight road racing exhaust for an older car once. Bullet muffler in back, should have just went straight pipe. Added the moroso to where the resonator would go, big difference inside, small difference outside(race muffler is a race muffler afterall) but it was quitter.
My work in progress...
Old 06-27-2018, 04:57 AM   #21932
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
Originally Posted by DJTTon View Post
Can someone please clarify if only the sunroof equipped cars have the drain tubes going down the sides of the interior? And how many drain tubes are there for sunroof equipped S14s?
If I remember correctly, there are 2 drain tubes on them.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 06-27-2018, 12:52 PM   #21933
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
Originally Posted by MAHALOHAWAII View Post
anyone selling some PS13 Silvia Bumper turn signals? (amber/clear) left and right? also willing to ship to FPO AP 96351?
B6125-44F00 (LEFT)
B6120-44F00 (RIGHT)
make a WTB thread and don't shit up this one.
jumpman2334 is offline   Reply With Quote
Old 06-28-2018, 12:13 PM   #21934
mattrobertsxn
mattrobertsxn's Avatar
mattrobertsxn is an unknown quantity at this point
Can anybody here verify how many grounds to the starter there are on a KA24de?
Also, is there a certain position the starter needs to be in for the car to turn over or can you just put it in there, ive been trying to start my car after rebuild and my starter is just making a weird clanking sound. lol i love this dumb question thread
mattrobertsxn is offline   Reply With Quote
Old 06-28-2018, 02:12 PM   #21935
unicoder
unicoder's Avatar
unicoder is an unknown quantity at this point
one ground. But its a best practice to run an extra ground strap from it to either your chassis or batteries negative terminal.
as long as it has power and ground and the belt is tight you should be good. If the starter is clanking it should also be turning the engine over, if its not turning starter is likely bad
5.3 V8 Swap w/ Nitrous
unicoder is offline   Reply With Quote
Old 06-28-2018, 07:13 PM   #21936
Xaser
Xaser is an unknown quantity at this point
anyone know if the R32, S14 or S15 floor mats fit on S13?
Xaser is offline   Reply With Quote
Old 06-28-2018, 11:14 PM   #21937
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
r32 will not fit and s13/s14/s15/ have similar size and I would expect the s14/s15 floor mats to be a little bigger than the s13.
instagram
1on1 is offline   Reply With Quote
Old 06-29-2018, 12:22 AM   #21938
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
S14 front floor mats fit fine... though a little weird overlap on the trans tunnel on the drivers side. rears fit, but theyre a different shape
Old 06-29-2018, 06:27 AM   #21939
AnnaKendrick
AnnaKendrick's Avatar
AnnaKendrick is an unknown quantity at this point
(SR TypeX Blacktop RS Enthalpy Tune)
Problem 1: What would cause my rev limiter to stop working when hot? The last couple of drift events I've been to so far my car's limiter will work for like 1 lap and then just stop. After letting my car cool down in the pits the same thing happens the next time I go out, 1 or 2 laps and then the limiter is just gone. I don't have an aftermarket limiter or anything. And just to be clear when I say 'hot' I don't mean I'm running the car into the danger zone.
Problem 2: This may or may not be related to problem 1, but it would be nice if it is. Last event I did a lap when my car was running fine, there was no signs of it running poorly (just the usual limiter not working) Anyways I finish my lap and stop in the lineup and when it's time to move my car just would not respond to throttle, my idle was rough and fluctuating. Shut the car off checked my throttle cable, tps was plugged in, maf was good. Start it up again still the same. So after about 10 minutes of looking at various parts of my engine bay with my xray diagnostic vision I give up. Start the car up and now it responds to throttle. I was able to drive my car home but ever since that happened my idle has been really low and my car has been running a bit rich.
Any suggestions would help. I haven't really dove into diagnosing it myself yet, but a point in the right direction would be greatly appreciated before I start breaking shit in the garage.
AnnaKendrick is offline   Reply With Quote
Old 06-29-2018, 09:50 AM   #21940
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
do CTSV calipers clear 17x9.5 +15 MB Battles?
ZenkiKid is offline   Reply With Quote
Old 06-29-2018, 11:08 AM   #21941
mattrobertsxn
I relocated my battery while rebuilding my motor, does anybody know where this second plug leads too? I know the first one is the fuse box.... anyone?
Old 06-29-2018, 11:27 AM   #21942
mattrobertsxn
And an add-on to above question, do i even need that or can i just run it straight to the starter and call it a day?
Old 06-29-2018, 02:54 PM   #21943
Xaser
Thanks guys!
Old 06-29-2018, 03:59 PM   #21944
jumpman2334
if you don't get your answer here, hit up the CTSV caliper guy
Old 06-30-2018, 07:05 AM   #21945
I'm Redline
Don't know about Battle's, but Square 17x9 +15 are good to go with CTSV calipers. My freind Rob has them on his coupe
Old 06-30-2018, 12:39 PM   #21946
brokeboi01
brokeboi01's Avatar
brokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enough
Took inside the top and and noticed this rough edge. Sign of engine wear or just some random sr bit?
brokeboi01 is offline   Reply With Quote
Old 06-30-2018, 06:18 PM   #21947
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
Looks like a leftover from casting. Is it attached or can you get it out with a magnet?
Sent from my SM-G960U using Tapatalk
lunchmeat is offline   Reply With Quote
Old 06-30-2018, 06:35 PM   #21948
Agamemnon
Agamemnon's Avatar
It'll work with 4 pot Brembos. If you want the 6 pot you'll probably need to run 18's.
Old 07-02-2018, 01:33 PM   #21949
VTEC_lol
VTEC_lol's Avatar
VTEC_lol is an unknown quantity at this point
any major differences between redtop/blacktop/notchtop transmissions? my notchtop spun a bearing and I wanted to buy a forged blacktop but will it fit in my old tranny?
I'm guessing yes but just want to be sure
E: also out of curiosity, how much power can the tranny hold? the new engine would have all the stuff necessary for more than 480hp, and has a stage 2 clutch, but how much can the tranny take?
VTEC_lol is offline   Reply With Quote
Old 07-02-2018, 04:09 PM   #21950
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Yes, the transmission is the exact same. Go ahead and buy a couple of replacements if you're running that kind of power. They easily shatter at 3-350hp.
Old 07-02-2018, 04:11 PM   #21951
Hoffman5982
Trader Rating: (25)
Can someone tell me why my car dies when I put it in gear. It will idle and rev just fine but as soon as I go into any gear, it shuts off. No, there is nothing wrong with the clutch engagement, it is electrical. I don't even get to release the clutch before it shots off. I'm thinking I just need to order a wiring specialties harness
Old 07-02-2018, 04:31 PM   #21952
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
There's slight gear ratio differences between S13/S14/S14a transmissions, but they share the same bellhousing bolt pattern and are pretty much interchangeable. Just make sure to reuse the speed sensor for your chassis. (Use an s14 sensor in an s13 trans for example)
S15 trans will bolt up also, but you'd have to change flywheel, driveshaft, and crossmember.
Old 07-02-2018, 04:32 PM   #21953
jumpman2334
if its a 6 pot, you will have to run 18s. I have IS-F calipers, which are basically the same thing as 6 pot CTSV bremos with minor exterior changes and they barely fit under my 18" rays that have the most aggressive face design.
Old 07-02-2018, 10:22 PM   #21954
Standard
Standard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud of
Yeah definitely make sure your starter belt is tight, right after you fill your blinker fluid and grease your muffler bearings, should be good to go LOL
Standard is offline   Reply With Quote
Old 07-03-2018, 04:54 AM   #21955
I'm Redline
CD009. Swap one in. New from Nissan for around $1800
Old 07-03-2018, 05:58 AM   #21956
VTEC_lol
VTEC_lol's Avatar
Gotta think about that if/when I blow the current one, can't really afford to buy a new one since the engine itself is expensive af plus new turbo, intake, exhaust, chip, injectors etc to get the 400+ hp. Hopefully the tranny will hold for at least one year
Old 07-03-2018, 06:50 PM   #21957
AnnaKendrick
My SR tps is reading 3.7v at WOT KOEO. Is this in spec?
Old 07-05-2018, 06:24 PM   #21958
Hoffman5982
Trader Rating: (25)
Old 07-05-2018, 06:25 PM   #21959
mattrobertsxn
What is this ka24de
Old 07-06-2018, 01:17 AM   #21960
1on1
1on1's Avatar
^ EGR Valve Control Solenoid
Did you do anything to your car before this issue happened or did it start out of nowhere?
instagram
