Old 05-17-2010, 04:33 PM   #1561
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
^^Seems you have a 89-90 fan. Looking at your condensor from the front of your car, it should be placed on the left side. There is only one way it bolts on. Someone will have to post a picture for you. I no longer use that fan.
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
Old 05-17-2010, 04:47 PM   #1562
nddavis2
nddavis2 is an unknown quantity at this point
Thanks for the help. So it should go over on the side of the alternator, upper radiator hose, battery, etc. Any shot you remember where it bolted to? Is it directly to the radiator or to something else? This would put it behind the fan shroud correct? Sorry for so many questions. Getting annoyed as hell. Putting a/c into a car that had it taken out is a pain.
nddavis2 is offline   Reply With Quote
Old 05-17-2010, 04:56 PM   #1563
MandTPhotography
MandTPhotography is an unknown quantity at this point
What are good tires that aren't terrible expensive that stretch well?
Tire size - 225/45/17
Wheel Size - 17x9.5
Options that don't such ass like Fuzion ZRI's I currently have?
MandTPhotography is offline   Reply With Quote
Old 05-17-2010, 05:03 PM   #1564
nddavis2
Never mind about the fan. Pretty sure I found what it goes to and where it bolts at. If this isn't the case then I'll be posting tomorrow.
Old 05-17-2010, 05:05 PM   #1565
xpertsnowcarver
Trader Rating: (44)
No it should be in front, between the impact bar and condensor.
You say you have this fan, correct?
There is an L shaped bracket somewhere on the fan frame. That should be the top which bolts to a spot next to the hood latch.
My YouTube Channel
Old 05-17-2010, 05:44 PM   #1566
odmoht
odmoht's Avatar
Trader Rating: (36)
odmoht is an unknown quantity at this point
Feedback Score: 36 reviews
can anyone help me? having overheating problems.
when i turn on my heater, i get nothing but cold air, and my temp gauge goes to hot when im at idle and while driving.
could it be the heater core?
i just put in a new thermo stat, water pump is working, new alum radiator, new coolant temp sensor, and i tried to get as much air bubbles out as i could.
i also have a E-fan.
i havent messed with the heater core yet, cuz i duno how i guess
odmoht is offline   Reply With Quote
Old 05-17-2010, 05:57 PM   #1567
odmoht
odmoht's Avatar
Trader Rating: (36)
double post...lag
sorry.
Old 05-17-2010, 06:09 PM   #1568
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
did you run your heater on full blast while flushing the system?
WheelsDirty
Old 05-17-2010, 06:27 PM   #1569
nddavis2
Thanks for that pic. That's where I was thinking after I went and looked again. Not looking forward to taking off the bumper to put this on...
Old 05-17-2010, 08:45 PM   #1570
odmoht
odmoht's Avatar
Trader Rating: (36)
yes sir, i did run the heater full blast while flushing.
Old 05-18-2010, 12:12 AM   #1571
Nizmo_max
Nizmo_max's Avatar
Nizmo_max is an unknown quantity at this point
one quick question about 300zx front brakes...Is there a difference in front brake pads size in the 30mm caliper and the 26mm caliper? i have a 30mm caliper was jw if i have to get the speicfic size brake pads for my calipers?
Nizmo_max is offline   Reply With Quote
Old 05-18-2010, 07:41 AM   #1572
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
Did you mount the thermostat with the jiggle valve at the top (12 o'clock position)?
Nope. They are the same.
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 05-18-2010, 09:32 AM   #1573
odmoht
odmoht's Avatar
Trader Rating: (36)
yessir i did, when i put the t stat into the t stat housing, jiggly part was facin 12 o clock.
Old 05-18-2010, 09:47 AM   #1574
joshls2
joshls2's Avatar
joshls2 is a well-known jackass
check your heater core coolant switch and make sure it isn't stuck in the closed position. its likely to be the case. have a friend switch the heater on and off so you can see it with your own eyes.
your overheating is, I think, an unrelated issue. make sure you installed or thermostat properly. you should also do a coolant pressure test, there might be a leak you can't see. oh, and purging the system through the bleed screw isn't a system flush. run pressurized water in reverse through the rad then through the block's water jackets and then finally through the heater core using the heater core's coolant hoses. hope that helps!
joshls2 is offline   Reply With Quote
Old 05-18-2010, 11:25 AM   #1575
odmoht
odmoht's Avatar
Trader Rating: (36)
if my heater core switch is closed, hypothetically, how would i fix that?
will try the pressure test and how would i go about doing the reverse method? water hose?
thanks for information, very big help!
Old 05-18-2010, 11:46 AM   #1576
bermeo240
bermeo240's Avatar
bermeo240 is an unknown quantity at this point
Send a message via AIM to bermeo240
ok so i have problem..i had my lsd(kazz 2way) for around 5 months. recently i changed my diff oil.then i realized i was hearing some weird loud noises. my friend told me to put rear subframe collars on and that shuold solve the porblem cause supposely my bushing were blown. i put the collars on and got an alignment since i never got one since the coilovers were put on. now i still have the problem. i get the loud noises wen i make turns(u turns,sharp turns, and even not so sharp turns) they told em it was normal to make noises but i dont think its normal for when i hear this clunking and feel my tranny shake really bad. then i got a flat and the wheel shop pull the car up and my friend got under the car and realized that u can move/shake the axles away from the diff
this part:
that is not my diff. jsut used it as and example
can that be it? or something else?...but one thing i am sure. that that is not normal. any info would be great.
bermeo240 is offline   Reply With Quote
Old 05-18-2010, 12:00 PM   #1577
jiggs
jiggs's Avatar
jiggs has made poor choicesjiggs has made poor choicesjiggs has made poor choicesjiggs has made poor choicesjiggs has made poor choicesjiggs has made poor choices
whats the difference between the 91-94 dohc ka motor and trans and the 95-98 dohc ka motor and trans?
JS4HATERS
jiggs is offline   Reply With Quote
Old 05-18-2010, 12:37 PM   #1578
Jwow
Jwow is an unknown quantity at this point
Hi, there. How much does it cost to change the power steering pump for my 97 240sx? Or maybe how much for the whole Power steering? Thanks a lot.
Jwow is offline   Reply With Quote
Old 05-18-2010, 03:17 PM   #1579
nddavis2
Quick a/c question again. Have the condenser fan mounted and wired. Could not get ahold of the factory clips so wired the black wire from fan to the black wire for a/c from the control and the green wire i believe it was to the brown/white wire that also controls a/c. Is the fan supposed to come on as soon as the a/c button is pressed or does there have to be coolant in the system and the compressor kicked on?
Old 05-18-2010, 03:38 PM   #1580
ki_JDM_ds
ki_JDM_ds's Avatar
Trader Rating: (56)
Feedback Score: 56 reviews
How long are the 300ZX 2+2 Rear E-Brake cables? I have a set of 300ZX cables but want to make sure they are correct for my S13 before I start tearing into it.
Thanks in advance!
ki_JDM_ds is offline   Reply With Quote
Old 05-18-2010, 04:21 PM   #1581
nathanong87
nathanong87's Avatar
this part:
sounds like backlash. who installed the diff?
natelife.tumblr.com
Old 05-18-2010, 04:40 PM   #1582
GunmetalSR
GunmetalSR is an unknown quantity at this point
is there anyway to get and use codes for all the zilvia smileys bc the ones on zilvia are amazing
GunmetalSR is offline   Reply With Quote
Old 05-18-2010, 06:32 PM   #1583
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
has anyone tried mounting 88-92 firebird gta meshies on a zenki?
they look like this
the bolt pattern is 5x4 3/4" ????? wtf kind of bolt pattern is that
oh and they're 16x8 so they're not too big i just don't know wtf that bolt pattern is lol
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 05-18-2010, 06:58 PM   #1584
Corbic
Corbic's Avatar
they look like this
Bolt pattern dimensions
It's called Old-School SAE, if they don't fit, then they are obviously not the Japanese based 5x114.3.
Old 05-18-2010, 08:29 PM   #1585
Marc240
Marc240's Avatar
Marc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-known
Wheel Size - 17x9.5
Falken tires tretch nicely. Also look into zexius i-427's. I run them on my car. Good grip for daily, soft tread design, stretches easy. If you want to spend a little more money. Look into the Nitto Neo-gen tires
this part:
Backlash. Also there are bushings inside and diff for the output shafts. they might be blown.
To do it yourself. Probably looking around $100. The whole powersterring setup will be expensive. Also if your having a shop do the work
they look like this
Those will not fit 5x114.3/5x4.5
They are a GM based wheel pattern. Ford is the only other american company that is compaptable with some japanesse auto makers.
http://i48.photobucket.com/albums/f209/mj2545/logo.gif.com
Marc240 is offline   Reply With Quote
Old 05-18-2010, 08:55 PM   #1586
jing
jing's Avatar
jing is an unknown quantity at this point
I have a set of Stance GR+ for my S13 but to my surprise, I have an S14 5-bolt conversion up front. As such, the spindle bolts will not fit in the mounting holes on my coilovers. From what I have researched, here are my options:
1. Get S13 spindle bolts, then get sleeves from 5lugsleeves.com to fit in the spindle to fit the S13 bolts.
2. Drill out the mounting holes on my coilovers to accomodate the bigger 19mm S14 bolts.
3. Buy S14 lower mounting brackets from Stance.
#1 is sold out unfortunately and it's a few weeks wait which I don't feel like waiting around for. #2 would affect the ability to resell them in the future. #3 is the most expensive but the "right" way to do it.
Do I have any other options?
jing is offline   Reply With Quote
Old 05-18-2010, 08:57 PM   #1587
zx6r1852
zx6r1852's Avatar
zx6r1852 is an unknown quantity at this point
hi i wanted to know how many stock front ends there are for an s13 and what are they called and how can you tell them apart and what years they come stock on?
zx6r1852 is offline   Reply With Quote
Old 05-18-2010, 10:14 PM   #1588
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
they look like this
They fit I have them on mine
FS OEM RB25 PARTS
Smurf_240SX is offline   Reply With Quote
Old 05-19-2010, 04:37 AM   #1589
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
what do you guys say about Greddy RZ BOV?
i heard of people saying they leak? true?
i was going for HKS. i tried searching HKS BOV VS Greddy RZ BOV but nothing except for 1 but it was for SRT folks. i would like to hear your opinion.
if you have experience of the Greddy RZ BOV, how long did it last for you? any leaks? tell me something
killer240 is offline   Reply With Quote
Old 05-19-2010, 04:50 AM   #1590
Corbic
Corbic's Avatar
How much PSI are you running?
Only in the 2NR industry would people pay +$50 for a spring actuated pressure valve.
