06-06-2017, 02:32 PM | #1 |
Smog help!
I have a 97 Kouki that had a auto to manual trans swap.
Found out it currently has an auto ECM and is giving me a check engine light for the IAC valve. I can't seem to find a 97 manual ECM anywhere. Question is: Would I be able to run a different year manual ECM? What are my other possible options? Thanks guys |
06-16-2017, 03:16 PM | #3 | |
There are a ton of threads that address this issue, especially when doing the swap. Use the search function. you must use a 5 speed ecu in order to pass smog for the kouki. I believe you can use a 5 speed ecu from a zenki but you need to repin/ relocated some of the wires at the ecu.
