Old 06-25-2014, 04:07 PM   #3061
quickdiversion
quickdiversion is an unknown quantity at this point
Awesome!
Great to see someone else is going holset. And posted right under mine!
I wanna know your numbers after you get tuned so we can compare!
quickdiversion is offline   Reply With Quote
Old 06-25-2014, 04:30 PM   #3062
speedfiend
Trader Rating: (68)
speedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to all
Feedback Score: 68 reviews
Send a message via AIM to speedfiend
Originally Posted by quickdiversion View Post
Awesome!
Hahah yeah I thought it was a fitting time!!! Im running the HX35W with the BEP .63 a/r exhaust housing. 850cc injectors, HKS 256/264 cams and other supporting mods. Gonna be tuned with PFC L-jetro. Whats your setup consist of?
speedfiend is offline   Reply With Quote
Old 06-25-2014, 04:50 PM   #3063
quickdiversion
haha, I have the list made so I am gonna copy and paste
Rear suspension;
lower tie brace, gtspec
lower A-arms, nismo
lower toe arms, godspeed
upper camber arms, spl
upper traction arms, spl
sway bar, godspeed 28mm
sway bar linkage, megan racing
soild rear subframe bushings, DIF
rear axle housing bushings, nismo
adjustable coilovers, godspeed
Front suspension;
Lower Control Arm, OEM
Lower pillow arm, Top Speed Pro 1
Coilovers, Tein
sway bay, godspeed 30mm
Steering;
330MM steering wheel, Sparco
KA24DE power steering lines and reservoir swap
Inner tie rods, tein
Soild outter tie rods, tein
tie rod boots, nismo
Steering knuckles - converted to S14 knuckles
Brakes;
rear R32 5-lug swap
front S14 5-lug swap
R32 GTS-T calipers front and rear
300zx 2+2 e-brake cables
Cross drilled and slotted rotors
Ceramic brake pads
Z32 to S13 conversion steel braided lines for brakes
300zx master cylinder
Body;
S13 to S15 conversion fenders +30mm over, Charge Speed
rear over fender FRP composit +50 over, Duraflex
rear bumper, Uras Type S
S15 front bumper, Charge Speed
Vented skirts, cut, shaved, and fitted for flush mount, FRPkits - Not yet mounted
S15 headlights, OEM
Wheels;
Rota P45R 18 18x9.5 +12 all around
Tires;
275/35ZR18 99W,
Engine; Top end;
chemically cleaned
Full port and polish
gasket matched intake and exhaust
rocker arm stoppers, Greddy
solid lifters, tomei
cams 270 in 270 out 12.5 high lift, tomei
adjustable cam gears, tomei
type A single springs 12.5 high lift, tomei
3 angle valve job, and ressed valves
Valves were unshrouded for better breathing and combustion
decked flush
new timing chain tensioner, oem
polished intake plenuim gasket matched, greddy knock off
321 steel mandral bend exhaust manifold.
cold spark plugs, NGK 8
1.2mm metal headgasket, Cometic
Bottom end;
Chemically cleaned block
Decked
Crank- micro polished, 2 pounds shaved, balanced
Pistons - CP, Balanced to crank
Rods - Eagle, Balanced to crank
Mains - ARP
Cap bolts - ARP
New oil pump timing cover - OEM
New water pump - OEM
New guides - OEM
New timing chain - OEM
New tentioner - OEM
New oil strainer -OEM
Motor mounts - Nismo
Alternator - Quest 110 AMP
Oil filter sandwich plate - Circuit sport
Oil lines -10 AN - Custom
Oil filter relocated to frame rail
Oil cooler - 14 r ebay
Over sized, baffled oil pan - Tomei
Turbo setup;
HX35 7 blade turbo from 2002 dodge cummins diesel
CRX forward mounted top mount manifold
-6 AN oil inlet feed
-10 AN oil outlet
Flap welded shut for external wastegate
Tial external watsegate 18PSI spring weight
Exhaust;
3in downpipe
3in tespipe
3 1/2in exhaust, HKS HiPower
Computer/Electronics;
NIsmotronic (To Be)
LS2 Truck coil packs w/ individual ignitors
Omni 4 bar map sensor
Boost Controller E-VCS
Fuel pump wired individually
Ignition wired individually
Wideband - AEM Uego
Boost Gauge - AEM Uego
Cooling;
3 core racing radiator, Megan
low temp thermostat, Nismo
Raditor hoses, Samco
s14 raditor neck with turbo line inlet, oem
2 core intercooler and kit, Greddy
coolant lines redirected cut and fit for left hand drive
Drivetrain;
1 pc short shifter, Megan
1 pc steel driveshaft, Driveshaft Shop
180sx rear pumpkin 5 bolt axles, oem
2-way diff, Kaaz
Fuel Delivery;
280L/pr hour fuel pump, Sard
Fuel pressure regulator, Sard regular type
Fuel Pressure Setting Meter, Sard
1000cc top feed injectors, Injector dynamics
Upgraded fuel line sizes from 1/4 in to 5/16 in inner diameter
Fuel pump independently rewired for 14.7 volts
Currently running 55psi fuel pressure
I think that's all of it.... haha
Old 06-26-2014, 02:42 PM   #3064
SGTsideways
SGTsideways is an unknown quantity at this point
my addition
SGTsideways is offline   Reply With Quote
Old 06-26-2014, 04:29 PM   #3065
Super_OK_S13
Super_OK_S13's Avatar
Super_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud of
Thanks d-nice!
SGTsideways thats a clean/organized bay. Good job!
Super_OK_S13 is offline   Reply With Quote
Old 06-28-2014, 01:37 PM   #3066
VAs13
VAs13's Avatar
Trader Rating: (28)
Feedback Score: 28 reviews
Old 06-29-2014, 12:52 AM   #3067
mrfyzv
mrfyzv is an unknown quantity at this point
mrfyzv is offline   Reply With Quote
Old 06-29-2014, 12:02 PM   #3068
shaggy0778
shaggy0778's Avatar
shaggy0778 is an unknown quantity at this point
shaggy0778 is offline   Reply With Quote
Old 07-02-2014, 06:45 PM   #3069
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Originally Posted by tek18b_jimmy View Post
Bay update. CHASEBAYS oem brake/clutch line kit. =)
Notice any difference in brake feel with the chase bays setup?
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 07-02-2014, 06:59 PM   #3070
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
He will notice a difference when the line pops and he loses brakes in all four corners at once.
-Edit-
Oops, thought this was about the Chase Bays brake booster delete setup.
Old 07-02-2014, 09:48 PM   #3071
Super_OK_S13
I did not notice any difference in the BRAKE pedal feel at all.
Although the clutch is different, in a way that I can feel the vibrations slightly but nothing insane, (which I expected from removing the "dampening box") before the slave cylinder and running straight to the slave from the clutch master)
Old 07-02-2014, 10:30 PM   #3072
angel mkiv
angel mkiv's Avatar
Ok cool Ima go that route but make my own kit since there's a big fittings/line store local. According to what I've seen online is everything is a m10x1.0 thread pitch, and a -3 line. So I'd just measure out the lengths I need and I bet it would cost a fraction of what chase bays is charging for there kit which is 199$ plus shipping
Old 07-02-2014, 10:49 PM   #3073
Super_OK_S13
yea, most hydraulics shops can make them but depending on the fittings/kind of line it can get expensive. It was somewhere in Lancaster PA that a friend bought a line for his hydro e-brake (I think it was around 3-4ft) it cost about 60$.
Old 07-03-2014, 07:02 AM   #3074
Penguin
Penguin's Avatar
Penguin is an unknown quantity at this point
Penguin is offline   Reply With Quote
Old 07-03-2014, 08:01 AM   #3075
ka-titties
ka-titties is an unknown quantity at this point
you can put that kit together for a fraction of the cost. that's what I did.
ka-titties is offline   Reply With Quote
Old 07-03-2014, 08:13 AM   #3076
EvilEgg13
EvilEgg13 is an unknown quantity at this point
EvilEgg13 is offline   Reply With Quote
Old 07-03-2014, 09:07 AM   #3077
JBB
JBB is an unknown quantity at this point
Originally Posted by VAs13 View Post
snip
Holy catch can....I mean TANK!
JBB is offline   Reply With Quote
Old 07-07-2014, 07:44 AM   #3078
DRFT180
DRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud of
S14 Build
DRFT180 is offline   Reply With Quote
Old 07-07-2014, 10:42 AM   #3079
Mannykiller
Mannykiller's Avatar
Mannykiller is an unknown quantity at this point
+1 for team BW EFR!!! Finally Finished with this bay...although I'll be re-doing my ducting. Bigger...Better...Stronger.. faster!!!
IG:@AAPARKAH #ThisIsTheWolf
Mannykiller is offline   Reply With Quote
Old 07-07-2014, 03:41 PM   #3080
Javier13
Javier13 is an unknown quantity at this point
http://www.youtube.com/watch?v=3_leO68-aBU
Javier13 is offline   Reply With Quote
Old 07-08-2014, 11:29 PM   #3081
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
Just thought I'd add a more updated photo of my engine, since Touge Factory is getting it closer and closer to completion!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 07-09-2014, 12:13 AM   #3082
bova17
bova17's Avatar
bova17 is an unknown quantity at this point
hopefully will be finished soon, just need a good sr20 crankshaft
bova17 is offline   Reply With Quote
Old 07-09-2014, 10:52 AM   #3083
Mannykiller
What on earth is going on with that intake? Double plenum madness?!!
Old 07-09-2014, 12:12 PM   #3084
DRFT180
Dual plenum intake manifolds eliminate turbulence inside the first plenum and allow an even distribution into the second plenum usually through a uniform slot in between the two. Helping to fill each runner with the same volume of air.
S14 Build
Old 07-09-2014, 03:10 PM   #3085
ka-titties
interesting
Old 07-09-2014, 10:25 PM   #3086
Bushido
Bushido's Avatar
Old 07-09-2014, 10:28 PM   #3087
bova17
bova17's Avatar
I feel like a dual plenum would make boost come on slower because there is more space for air to fill to create pressure
Old 07-10-2014, 02:06 PM   #3088
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
That all depends on the volume of the plenum.
All it is really doing is separating the the plenum inlet and main plenum body by ports to equalize pressure and flow across the plenum.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 07-10-2014, 08:51 PM   #3089
RB2.5
RB2.5 is an unknown quantity at this point
Wouldn't a much larger plenum( assuming there was space) negate the need for a dual plenum design? Do you have any more velocity charts for different designs MR Drift180? Thanks!
RB2.5 is offline   Reply With Quote
Old 07-15-2014, 03:58 AM   #3090
muski
muski's Avatar
muski is an unknown quantity at this point
IG: muskkiii
muski is offline   Reply With Quote
battery relocate
