11-28-2017, 02:25 PM | #1 |
S13 - 375hp - SR20det - $5000obo
Ran great and was used as a daily for a little while. Started to pull it apart to run some parts on my Silvia, but ended up selling the Silvia and this car just sat in my garage. No desire or time to get it running again, so just selling it as is. Need to sell ASAP as I'm leaving for Japan at the end of January.
$5000 OBO takes the whole car. Get it running again, flip it, make some cash; I don't care what you do with it - I just don't have time for it. Motor: SR20DET Redtop Tune: RS Enthalpy @ 375-390HP - I've never had it dyno'd, but the tune is for just under 400HP. 2871R .64 A/R GT-RS with HKS wastegate Taka water/oil lines Hybrid Dynamics turbo adaptors Megan Racing Turbo Outlet Cat delete pipe Filled motor and tranny mounts Blitz DP 5zigen Rocket Exhaust Greddy RAS Brian Crower Stage II Cams Brian Crower Valve Springs and Ti Retainers Greddy FMIC HKS BOV Enjuku Hotpipe Deatchwerks 550CC injectors (Less than one year old) Circuit Sports Fuel Rail Z32 MAF S15 water pump Greddy oil pan S14 blacktop oil pickup Koyo Radiator FAL dual puller fans Apexi S-AFC II Freddy Intake Manifold RS-Enthalpy ECU Tune Walboro 255 fuel pump Nismo Radiator Cap SAMCO radiator in/out hoses Chase Bays Tucked Harness Engine bay is tubbed, stitch-welded, and painted gold. Fuse box relocated to glove box Battery relocated to trunk Aeromotive Fuel Pressure Regulator Transmission: Rebuilt trans in 2006 Spec Stage 5 Clutch (Less than 100 miles) Spec Pressure Plate (Less than 100 miles) New OEM Master Cylinder New OEM Slave Cylinder New Clutch Line Kaaz Advance 2-way Differential Suspension/Brakes: Z32 Brakes with drilled and slotted rotors (front) MR street coilovers Pilot STB’s F&R Ichiba 5-lug hubs Extended LCA's Shortened Knuckles P2M Rack Spacers Exterior: AIT Rear 30mm Overfenders Origin Roof Wing OEM Type X Wing Varrstoen (knock-offs) ES2 18'' 5x114.3 18x10.5+22 Rear Only Brand New windshield Interior: Disassembled & switch panel uninstalled - dash removed but there. Sparco 340mm Wheel (not mounted yet) Center Mount Guage Pod Pillar Guage Pod Greddy spin knob NO HOOD, KIT, OR SEATS. |
01-21-2018, 05:41 PM | #6 |
Having previously spoken to the OP, the car doesn't run because a switch panel was in the middle of being wired in and never completed, or vice versa, and a switch panel was in the middle of being taken out.
I'm 99.9% sure this car is sold though. |
04-04-2018, 12:30 PM | #9 | |
You are correct about what was needed. |
