01-27-2009, 06:36 AM | #31 | ||
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
Then again... This IS Zilvia.
http://zilvia.net/f/sale-items/24807...-stuff-fs.html |
01-27-2009, 04:29 PM | #33 |
For track use, i use the stock clutch and shroud, but i also have an additional pusher fan on long waits at the track.
Nothing says racecar like a stock car with no interior. |
01-27-2009, 04:29 PM | #34 |
Just make sure to keep the shroud, without it the fan is useless. You can even run some sealing foam around the edges where it meets the radiator for even more air direction.
01-27-2009, 04:37 PM | #35 |
all good stuff here. ima try an e-fan for a little, and maybe make a diversion tunnel. also what temp is normal for KA im going to install a temp gauge first..then see the difference with the clutch and e fan
01-27-2009, 04:44 PM | #36 | |
the new variable speed diff fan control unit looks like a cool addition to an electric fan setup if it can actually controll the speed, voltage of a large draw electric fan. But at 200 bucks introductory pricing I dunno how many cheap 240 owners will take that dive for the convenience of "engine bay space" |
01-27-2009, 07:16 PM | #38 | ||
$200 is acceptable at that point, and $50 for altima fans is like eating off the dollar menu.
01-27-2009, 10:09 PM | #43 |
you guys are clowns.
As far as running out of shit to sell, I can't wait for that day to come. I've still got a friend's basement full of shit I need to inventory. I've learned some Schassis parts really do multiply. Wiper motors especially. I must have 40 of those fucking things.
02-03-2009, 09:48 PM | #45 |
Here's a question I've never seen brought up.
Is the stock fan clutch thermostatic? Such as, when temps rise due to traffic, racing, drifting, ect., does the clutch "lock up" more because of the hotter air flowing bye causing the fan to spin faster? I have been through: Stock Altima's Taurus and back to stock I've learned my lesson |
02-03-2009, 10:09 PM | #46 | |
02-03-2009, 11:13 PM | #47 | ||
What was so wrong with altima fans?
02-04-2009, 08:19 PM | #48 |
I would say the Altima's were second best to the clutch fan. Only when properly ducted after cutting them up to fit. That made a huge difference, and the only thing I didn't like was the voltage drop when on. Also the temperature fluctuations you get with an e-fan.
I did not like how much of the radiator the taurus fans did NOT cover. A nice chunk of the radiator was not even being used. I did have a DiF fan controller, so they were not constantly running For the clutch fan, just make sure you have all the pieces to the shroud and it is sealed to the radiator |
02-04-2009, 09:47 PM | #50 | |
My car barely gets warm with the fans off. With the fans on low, I can cruise.
Interstate? LOL.
02-05-2009, 07:30 AM | #52 | |
Your grounds are too far apart. ground everything at a grounding block near the -terminal and you'll notice the "noise" go bye bye! |
02-05-2009, 08:46 AM | #53 |
I have been down the "screw the clutch fan" road. Only to have my S14s constantly overheat at a light with the A/C on.
I just run the stock setup and keep my weight down to 175. (I hate fat arms) Here's a question for you guys: Can the infamous OEM fan blade cracking problem be solved by some epoxy or JB weld at the cracks? Anyone tried this? Does it mess with the balance and rotation of the fan if done properly? I need to figure something out before some fan blades jam their way into my engine bay. Thanks.
Don't mess with my monkey...he's loaded. |
02-05-2009, 12:49 PM | #56 | |
I'm sure it's heat related, and by infamous I mean very common. And that's the problem......it's not in good shape if the blades are cracking at the base!! Right?!?
02-05-2009, 02:21 PM | #57 | |
Nor has other people local to me who use to/still do have 240's. I'm not saying it's impossible for it to happen. I'm just saying that that is hardly a reason for me to be worried or see that as a reason to upgrade.
02-05-2009, 03:37 PM | #58 | |
I would say I've seen this problem on about 15 240s over the years. All 5 cars that have been in my possession, some I've bought trying to fix this problem, and then some on other owner's cars. All in all, a pretty wierd problem considering that the only wear and tear SHOULD be dirt on the blades. I guess I just live in the twilight zone part of CA.
12-06-2017, 12:44 AM | #59 |
So from this thread, I got that the only benefit of the electric fans are freeing up space. So if you were turbo charging the stock dual cam is it possible to run the stock clutch fan and shroud? Or would you need more space for the piping? And even then, would the clutch fan be able to keep the engine cool if it was turbo?
12-06-2017, 01:16 AM | #60 | |
Ayo that's crazy @originaldonjosh |
