Old 02-05-2012, 03:56 PM   #1
riprodder
riprodder's Avatar
Trader Rating: (30)
riprodder is an unknown quantity at this point
Feedback Score: 30 reviews
s13 How To: S13 Silvia Radiator Cooling Panel
I know that a lot of you out there would like an S13 Silvia radiator cooling panel but they seem to be kind of hard to come by. So I thought I'd share what I did with you all so you can enjoy one too.
First off, I started by purchasing one for the 240sx with the flip up headlights. But the problem with this one is that it has two ears that stick off for the front mounting points as you can see in the pic. You will need to cut these off so you panel will fit in the pocket between the headlight supports.
I marked a straight line with masking tape and used my air powered cut-off wheel to cut along the line. If you're careful, these can be cut off without hurting the finish. A dremel would also work but I wouldn't try a hack saw or sheer because it might distort the aluminum when you cut it. After making the cut, dress the edge with a block sander or file so it's not sharp.
Now it should fit on your car. I had to adjust one edge a couple of times to get the latch section to line up just right but with a little patience you can make one fit too.
These also look really nice with a pair of my headlight finish panels. You can contact me for more info about them if you would like a set.
Coupe Love!
riprodder is offline   Reply With Quote
Old 02-05-2012, 04:20 PM   #2
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
I like what you did here...very interesting and looks clean very clean
S-Nation S13 is offline   Reply With Quote
Old 02-05-2012, 04:23 PM   #3
ghost_silvia
ghost_silvia's Avatar
ghost_silvia is an unknown quantity at this point
You should have posistioned LIAM NEESONS face above the panels demanding you buy these!
I have silvia front end could you send me a pickup price for the 3 pieces?
ghost_silvia is offline   Reply With Quote
Old 02-05-2012, 04:42 PM   #4
riprodder
riprodder's Avatar
Trader Rating: (30)
I actually don't make the center cooling panel. This is just a write-up on how to modify one from a 240sx to make it work with the Silvia front clip. But I did send you a PM about the headlight panels.
Coupe Love!
Old 02-05-2012, 04:55 PM   #5
ghost_silvia
Responded, but what did you use for the tetxture bed liner?
Old 02-05-2012, 05:04 PM   #6
riprodder
riprodder's Avatar
Trader Rating: (30)
The headlight finish panels have a textured finish ingrained into the plastic and the cooling panel I bought was powder coated wrinkle black.
Coupe Love!
240sx, cooling panel, radiator, s13, silvia
