Old 11-20-2018, 12:53 PM   #1
madserv
madserv is an unknown quantity at this point
Send a message via MSN to madserv
Gear Grind on PowerShift
Hello ,
I want to ask i had install z32 gear into sr20det in my s14 silvia .
running ORC triple plate clutch with Type A Full Engagement Release bearing.
my shifts are normal and no noice or grind when changing gears. but in some track race or road race when i try to power shift the gear it dont shift and grind.
can you tell me what could be the reason of gear grinding in powershifts ?
is it my release bearing ? or sale cylinder or my gear syncros ?
please help.
thank.s
Follow Me On Instagram @madserv_s14
madserv is offline   Reply With Quote
Old 11-20-2018, 04:43 PM   #2
TheRealSy90
TheRealSy90's Avatar
Your synchronizers cannot slow the gears/shaft in time to allow the gears to mesh when you are full throttle shifting.
Such a good signature.
Old 11-21-2018, 04:50 AM   #3
madserv
what can i do to make it powershift. ???
Old 11-21-2018, 07:28 AM   #4
TheRealSy90
Set the car up with a standalone ems that supports no lift shifting.
Old 11-21-2018, 07:31 AM   #5
madserv
Already Running Aem v2
Engine Detail : Complete Built sr20det , with 6466 Turbo
makeing 538whp on 25 psi of boost.
running z32 gear with ORC triple plate clutch . with mazworx conversion kit.
Old 11-21-2018, 07:36 AM   #6
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
You can always build the transmission. Straight cut gears life.
e30gangsta is online now   Reply With Quote
Old 11-21-2018, 07:57 AM   #7
TheRealSy90
Okay, just because you have an AEM v2 doesn't mean that it's been properly set up for no-lift shifting. Is it cutting either fuel or ignition when you push the clutch to shift gears?
Old 11-21-2018, 11:36 AM   #8
madserv
well i need to ask that from my tuner
Old 11-26-2018, 12:28 AM   #9
madserv
Okey its on fuel cut. and not on ignition cut.
