07-08-2010, 08:45 PM | #1201 | |
Everyone should stop talking about the degredation of the "scene". As much as it sucks, there's nothing we can do. So let's just keep on keeping on, and eventually, we'll be all that's left. Back to suspension discussion.
07-08-2010, 09:08 PM | #1202 |
Have the D Max Steering Rack spacers been discussed anywhere yet? I haven't seen anything, but they seem legit. Dmax advertises 7-8 degrees of additional angle by using them. I have thought about ordering a set of these off Yahoo Auctions to compliment my PSM knuckles and Ikeya Formula tie rods. Any thoughts?
07-08-2010, 09:18 PM | #1203 |
^^u mean the same little spacers everyone makes? or are the dmax different?
I run two sets of the spl's. one between the rod and the rack and one between the inner/outer. gives waaayyy a lot of angle over stock and super cheap. |
07-08-2010, 09:22 PM | #1204 | |
AFC #1
07-08-2010, 09:25 PM | #1205 |
No, Dmax makes an adapter that threads into the steering rack like your innter tie rod does. Then you thread your inner tie rod into the spacer. This is also supposed to center the rack since the rack is naturally off-set (IE you have more turning angle to one direction and less to the other from factory, this is supposed to even everything out).
07-08-2010, 09:29 PM | #1206 |
http://zilvia.net/f/suspension/31985...ion-links.html
This is a link to a seller on zilvia. It's on the bottom of their listing.
07-08-2010, 11:17 PM | #1208 |
Dude, seriously, read like two pages before. He answered those questions!!! They are available now. You can make a request on how much you want, but they will calculate it out for you if you do not understand how everything works.
07-09-2010, 12:59 AM | #1211 |
If you have modded knuckles, you don't need to worry about over correcting.
But if you run a really low car with stock knuckles, and those super angle spacers, you will more than likely run into issues with over centering.
07-09-2010, 06:09 AM | #1212 | ||
Rear knuckles = not available yet.
07-09-2010, 08:50 AM | #1213 | |
So, turn your steering wheel full counter to the right, and look at it. Now turn your steering wheel full counter to the left and look at it. One side has a little bit more angle. Why is this? Well, the steering input to the rack is pushed over to one side of the car, naturally from the factory. (if you sat in the center of the car, it would be equal on both sides). The Dmax deal is supposed to compensate for this and give you the same amount of angle on each side (so the spacer's would be rh/lh specific, and that would apply to lhd/rhd specific as well). Mind you, this is all assuming my Japanese is on point enough to understand this thoroughly. I might try to take some pictures of the steering angle on one of my friends cars (how it has more to one side than the other) and post it up here tomorrow. (my car is torn apart right now or else I would use it as an example).
07-09-2010, 09:13 AM | #1215 |
I think Slidin' Sam might be correct.
Then again, none of my stuff was aligned correctly when I did my quick visual test on whether or not my steering wheel was centered or not. It still isn't, but I get the exact amount of turns from left to right, so I am happy. |
07-09-2010, 09:29 AM | #1216 |
is he talking about these Spacers?
Driftworks GeoMaster - Offset Rack Spacers | Steering | Driftworks over center correcting spacers. thats what is sounds like. Not the stance outter ends like someone just mentioned.
07-09-2010, 10:06 AM | #1217 | |
Yahoo Auctions: ?D-MAX????UP???????? S14?????? - INEX?2???? - Yahoo!?????? D-Max JP web-site: ÂØ‚êÅ*p‚t‚oÆ’AÆ’_Æ’vÆ’^Â[Æ’LÆ’bÆ’g Âb Æ’GÆ’AÆ’ÂÆ’pÂ[Æ’c‚È‚çD-MAX‚ÅÂFÆ’GÆ’AÆ’ÂÆ’pÂ[Æ’c
07-09-2010, 10:50 AM | #1219 |
Stance Super Angle Kit:
Super Angle Kit Dan, what do you think the maximum roll center correction you can do is?
07-09-2010, 12:30 PM | #1220 | |
seems like a worthy deal for 250. specially since they are bump steer corrected.
07-09-2010, 12:37 PM | #1221 |
Any amount of front knuckle roll center corretion can be done. Ive seen the range 1 to 4cm being offered in Drift Tengoku but anything over the 2.5cm that we have pictured on Tommys car will require additional labor and materials.
As for the rear knuckle despite claims from another company offering a knuckle that lowers the car 5cm, the actual R/C correction at the hub is limited to about 2.5cm or the axle boot will hit the upswept camber arm. Apart from the rear knuckle, our subframe solid risers provide correction to the rear end as well. that does not make any sense, because the steering angle spacer functions by letting the inner tie rod slip into the rack farther before it hits the back of the inner tie rod ball joint. The connection of the inner and outer tie rod is simply adjusting the overall tie rod length for proper toe alignment.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 07-09-2010 at 01:08 PM.. |
07-09-2010, 02:06 PM | #1222 |
Yeah, I was asking about the front. Thanks for replying. 4cm is pretty cool.
07-09-2010, 02:47 PM | #1224 |
Sure you can schedule the car whenever its convenient for you mon-fri 10:30-5:30
When I state the measurement its on the knuckle itself from where the taper hole mounting surface used to be on the knuckle to where it is after the mod.
07-09-2010, 03:24 PM | #1225 | |
Also, you don't necessarily have to have the ball joint located beneath the inner pivot for the suspension to gain negative camber under compression. As long as the angle between the imaginary line formed by the upper mount and ball joint and the imaginary line formed by the lower arm inner pivot and ball joint do not exceed 90 degrees at maximum, you will still get negative camber gain under compression. If you have a pillowball upper mount camber plate thing, that means where the spherical bearing is... so if you moved it in for negative camber, that changes the angle of that line a little bit. |
07-09-2010, 05:17 PM | #1226 | |
07-09-2010, 05:23 PM | #1227 |
So any idea's on the D-max angle spacers? Their website say's they use them with their knuckles...for backwards entries...the new mandatory gangsterness, lol!
07-09-2010, 05:26 PM | #1228 |
I'm guessing they work.
07-09-2010, 05:28 PM | #1229 |
I'm guessing that nobody on here has used them before and therefore nobody can give a real critique. Looks like I will have to test them myself...I will probably wait until September... gotta save for tires and everything for G1GP and Matsuri next month!
07-10-2010, 10:38 AM | #1230 | |
So what makes the S14 kit not work on an S13?? |
