03-25-2013, 11:58 AM | #91 | |
and yes their site says the springs lengths are 180mm, which is why im confused now. |
03-25-2013, 12:02 PM | #92 | |
I HAD THE SAME SET UP ON MY OLD COUPE AND WAS ABLE TO COVER CLOSE TO MORE THAN HALF THE TIRE WITH 205/40 WITH JUST 1 COLLAR REMOVED. the damn tire has nothing to do with how low the coilover can adjust. because of the problem i have, even if i had 215/45 or 205/45 my fender would barely be touching the tire |
03-25-2013, 12:07 PM | #93 | |
03-25-2013, 12:25 PM | #95 |
ive already emailed them on saturday when this happened. i havent called them because theyre close sat and sun. if they dont respond to my email, ill call them on my lunch break cause im at work. calm the fuck down.
03-25-2013, 12:31 PM | #96 |
Looks like you might have to be uncool for a while, sorry. But on the bright side, you probably wont dent your oil pan any time soon.
Sorry to hear you car got stolen though, that does suck.
* S14SR22 * 9.0 c/r * GT3071R * |
03-25-2013, 12:33 PM | #97 |
When I first put mine on (brand new Comp, purchased a few weeks back), I turned everything all the way down and felt the same way. You should max out front negative camber and pull out all collars. After doing that, I was still unsatisfied with the height, but then again my car doesn't have any drivetrain installed yet.
With a new top mount hole drilled, I'm happy with the front height (lots of negative camber, as a result). I've preloaded the rears half an inch (crushed to 6.5") and it's still not low enough so I'm going to get 6" Swifts. |
03-25-2013, 01:05 PM | #98 | |
i dont think adding negative camber will make a difference. my old coupe had -2.85 degrees of camber, 1 collar removed and was a lot lower than my current coupe. |
03-25-2013, 01:19 PM | #99 | |
03-25-2013, 01:21 PM | #100 | |
what im trying to achieve is this: this is the gap i have now: |
03-25-2013, 02:57 PM | #105 | |
03-25-2013, 03:07 PM | #106 |
I think the look he's goin for is for the sidewalls to be gone. Either way adding camber would probably increase the gap from fender to tire.
Just run a 255/45 all around and raise it lulz... Thats what I did. |
03-25-2013, 03:15 PM | #107 |
Pretty sure neg- camber in the front has little to do with it. I just pulled all my camber out of the front and it didn't change where the fender met the tire.
And I believe I am lower. Good luck bro! |
03-25-2013, 05:46 PM | #110 |
again, ive done this with my old coupe. ive gotten the look i wanted with 1 collar off. and yes i do realize my rack will be very close to the ground. never had a problem on my old coupe.
03-25-2013, 05:47 PM | #111 |
03-25-2013, 06:00 PM | #113 | |
Trader Rating: (39)
Feedback Score: 39 reviews
IG - allen.kerose |
03-25-2013, 06:48 PM | #114 |
03-25-2013, 07:03 PM | #115 |
Trader Rating: (39)
17x9j+35 17x10j+20 215/45/17 all around in this pic but i was rubbing so much up front it put a hole in my wheel well , so i went down to 215/40/17's and i was quiet lower than before with the smaller sidewall and zero rub
IG - allen.kerose |
03-25-2013, 07:55 PM | #118 |
Real weird man. Somethings seems weird. PBMS do go extremely low. I have them on my fc and im pretty dang low and still can keep going.
On the real though man if you need help or if they take too long to contact you to talk about it let me know. If i can help out i will. I actually live 10-15 mins from their warehouse here in San Diego. PM if I can help out, this is my dead week with nothing to do lol. |
03-25-2013, 08:26 PM | #119 |
i never said they were. im saying its better to have function rather than form then i said my megan's were low. never did i say megan's are more functional then pbm's.
But imo megan tracks are perfectly functional, actually i (with my own eyes) have never seen pbm's on anything race related, while megan tracks on the other hand are on the majority of the pro am drift cars that i see in the midwest. |
03-25-2013, 08:32 PM | #120 | |
