12-17-2014, 05:26 AM | #1 |
Any body know where the other end of this turbo line goes it wraps behind the motor
I don't where it ends up after it wraps around the motor I just got steel braided line and want to swap the hard lines out ImageUploadedByTapatalk1418819159.172659.jpgImageUploadedByTapatalk1418819173.539082.jpg I wrap tape around it so you can see it any body have there motor out that can take a pic
12-17-2014, 11:29 AM | #3 |
Thats a water line to cool the turbo? I had to change it months ago after it decide to break.. Very pqinful to replace. Connects to a hardline under the intake manifold.
You can sleep in your car, but you can't drive your house. |
12-17-2014, 12:04 PM | #5 |
My car is rhd, so my ac lines wasn't a problem.. Disconnect the trans mount and jack the trans up to clear space between the head and firewall
12-17-2014, 12:35 PM | #6 |
Yep I hate that line. To make life easier get the steel braided lines when you replace it.
http://www.frsport.com/DIF-10034-Bot...-_p_15427.html |
12-17-2014, 01:07 PM | #9 |
I did the exact same thing about a year ago when swapping to s15 turbo. Its already been said, but yeah, there is a hard line that it meets halfway between the hot and cold sides behind the head. I ended up just plugging that hardline and ran a new line off the water neck for future ease. Good luck
12-17-2014, 01:43 PM | #10 |
Trader Rating: (18)
Feedback Score: 18 reviews
Or... You could just snag up a S14 water neck and run a SS braided line to that!
Delete the line in the rear of head. Pain free with no headaches! |
12-17-2014, 05:06 PM | #14 | |
Trader Rating: (18)
Either way works fine. Get your self the S14 coolant water neck! Your going to love it! |
12-17-2014, 04:03 PM | #15 |
Either way - just make sure it's a reliable connection. Don't use a vacuum cap, it won't last.
S13 Hatch - Goes around tracks quickly DEFSPORT |
12-18-2014, 10:14 AM | #16 |
BTW - the cheaper way to go is to just drill and tap the S13 water neck and put a 1/8" NPT to whatever fitting you're using on the water lines (I've usually used -4, small and plenty of flow).
Takes a few minutes, and the fitting costs a few bucks. An S14 waterneck is kinda pricey.
12-18-2014, 02:58 PM | #17 | |
Pretty tits if you ask me. |
12-18-2014, 03:01 PM | #19 |
If you're using the existing M14x1.5 mm port for a temp sensor, then you need to do something to add the coolant return to it.
So why not just mod what you've got? People on Zilvia are so afraid of doing some light fabrication it's ridiculous.
12-19-2014, 05:53 AM | #20 |
I am in agreement with your last statement.
I utilized the existing port for my coolant return and then drilled and tapped the square pad on top for the sensor. |
