05-05-2015, 09:47 AM | #5221 | |
Trader Rating: (163)
Feedback Score: 163 reviews
05-05-2015, 02:20 PM | #5223 |
FWIW -6AN lines slide on 5/16th barb perfectly. I ran full new -6AN fuel lines and clamped them onto my fuel hat to avoid modification for a bulkhead fitting.
05-10-2015, 10:04 AM | #5224 |
Trader Rating: (53)
Feedback Score: 53 reviews
Any of my 1JZ peeps looking for a harness and ECU?
http://zilvia.net/f/showthread.php?p...14#post5873714 |
05-10-2015, 12:36 PM | #5225 |
Few small question!
1. I want to see your fuel line setup. I know people are running the stock line and doing the switch in the engine bay. Do you have other cleaner ideas. Wanna see what kind of holder you use. 2.Do you use the lower mk4 lower radiator hose? 3.While we're at it. has anyone did a downpipe that connects to the stock catback location |
05-10-2015, 01:17 PM | #5226 |
Make sure you don't get the Aluminum fittings. They need to be stainless steel or mild steel. The aluminum ferrel sets don't not crimp the factory steel hardline and will leak.
05-11-2015, 01:26 AM | #5227 | |
2. yes you can use the mk4 lower radiator hose 3. i went with custom exhaust so don't know the answer to that one
XXXwhp 2jz, e85, 1650cc, BW s390, v160 ; instagram: krayziejoker |
05-11-2015, 05:59 AM | #5228 |
Hey all, I know this isn't entirely JZ related, but I figured I'd ask. I'm having trouble getting my speedo to read anything. I have a Marlin Crawler VSS from my R154 to a Dakota Digital SGI-5, then to the speedo itself. When the car is moving, the light on the Dakota is flashing, so I know it's receiving a signal. But I can't seem to get the signal to the speedo at all. I've tried every setting that I've seen by searching for the problem, but haven't been successful. any ideas?
Daily: '99 Pontiac Trans Am. Projects: '96 S14, '87 Merkur XR4Ti |
05-11-2015, 12:45 PM | #5230 |
10an lines to a 30 row in the front passenger side vents... I also have a fan but haven't needed it yet
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
05-12-2015, 10:17 AM | #5233 |
Anyone have Heater hose part numbers for 1jz s14?
Found this but they want $325 for hoses
~755whp 1jz.~ Proefi 128, e85, 1200cc, 6265, 39psi |
05-12-2015, 10:48 AM | #5234 |
Earls 16? Row Cooler, No fan. No real issue keeping the trans cool doing street pulls and cruising, haven't pushed it hard repeatedly, might grab a bigger cooler with a fan in the future.
05-12-2015, 12:30 PM | #5235 |
Does anyone happen to have a picture of a CD006 next to a R154/W58 or R154? Looking for some size comparisons.
05-14-2015, 11:12 AM | #5237 |
I just was doing mine (S13) last night. I ordered Part numbers 19048 and 18774 from RockAuto off of a suggestion in here and they look they'll mostly work. I had to cut one and buy a union for the upper hose but close enough. Good luck!
Has anyone had problems using a SS clutch line from KA/SR and using it for the R154 slave cylinder? Mine hooks up just fine, good length and all but leaks a bit at the line/slave cylinder connection. It's on there good and snug but still doesn't hold. Might try using a crush washer to help. Any suggestions or input? |
05-14-2015, 11:15 AM | #5238 | |
Is that for 2j? looks like the upper will connect to the top of the head, vs 1jz has to 180 back around
05-14-2015, 11:17 AM | #5239 | |
Edit: I'll try and explain in the mean time. On the unequal S shaped hose, I cut the shorter end off so there was a long 'r' and a short 'r' piece. The short 'r' hooks perfectly to the lower heater hose spot that's right in front of you when looking at them. The long 'r' I've turned to face the driver's side of the engine bay and taken the other heater hose and turned it into a 'C' so that it faces the long 'r'. I didn't finish last night but it looked like a union will connect them just fine. |
05-14-2015, 11:18 AM | #5240 |
For sure, I ended up cutting the old ka heater hose and got the lower 90deg on. but the top seems a bit harder.
05-14-2015, 04:25 PM | #5241 | |
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
05-14-2015, 09:10 PM | #5242 |
Trader Rating: (18)
Feedback Score: 18 reviews
I ended up in Mexico this weekend and pissed off quite a few people with V8's.
https://www.youtube.com/watch?v=uqTc...w#action=share
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
05-15-2015, 07:00 AM | #5244 | |
Nice!!! Sounds like you need some beefier tires lol I loved the 4 wide where you came storming thru like no body's business
05-18-2015, 11:10 AM | #5245 |
Trader Rating: (18)
I have a spare tercel throttle cable for anyone needing to make a proper fitting one for their swap. Pm me if you're interested.
05-19-2015, 01:59 AM | #5246 |
Does anyone besides CX Racing make a throttle cable bracket for the swap? I have a non VVTi in my S14 so it doesn't work..
I just purchased a brand new S14 cable and I would rather use this one. I currently don't have access to a welder to modify my existing bracket. |
05-19-2015, 08:50 AM | #5247 | |
When I first got my swap running, I just got creative with my old KA bracket... Now that I think of it, it might have been the cruise bracket IDK...
05-19-2015, 12:47 PM | #5248 |
05-19-2015, 01:00 PM | #5249 | |
A quick search of this thread... Quote:
