04-06-2017, 04:32 PM | #1 |
Z32 e brake cable brackets
Hi there, I have a set of Z32 2+2 e brake cables about to go onto my Z32 brake conversion on my s13. Im just curious if anyone could send me a diagram possibly of where I need to drill holes in a bracket to line it up.
I've searched already. Thank you |
04-06-2017, 09:17 PM | #2 |
you didn't try very hard. found this by accident just now
http://ttuned.com/forums/index.php?showtopic=489662 |
04-07-2017, 12:26 AM | #3 | |
05-28-2017, 09:41 PM | #4 | |
05-29-2017, 08:26 AM | #5 | |
GM2 (SW/AW)
Incorrect. This bracket has been duplicated MANY times.
KA-T for life! Current for sale advertisement |
05-29-2017, 09:16 AM | #7 | |
GM2 (SW/AW)
So are you saying the distance between the threaded bolt holes on your car are not roughly 4.5" apart?
Because I just got under mine and they are. That's probably why I had this exact type of bracket on a mere week ago. Weird
05-29-2017, 09:26 AM | #8 |
That's what I'm saying.. I attempted this yesterday following measurements to the T and wasted a good part of my morning. The holes are more than 115mm apart and the cable studs are off (too low) as well.... guess I should of taken measurements myself before cutting and drilling. It's more like 4.75" from center to center.
Sent from my iPhone using Tapatalk |
05-29-2017, 09:57 AM | #9 | |
GM2 (SW/AW)
Maybe it's that big ass hunk of aluminum that's your problem?
05-29-2017, 10:13 AM | #11 |
Yikes. I literally eyeballed two pieces of flat steel, cut, held up to chassis hole, marked it where it looked like the hole was, and for the cable. Drilled the holes, put the steel in a vice and bent t up. Bolted it on. Smooth sailing
MRP Manufacturing |
05-29-2017, 10:19 AM | #12 | |
Just my luck for going "ADD" on my car.... 🤦 Sent from my iPhone using Tapatalk |
