Old 06-20-2018, 10:13 AM   #1
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
Ka24de ignition timing trick
A lot of ppl seem to be under the impression when u set your distributor timing, that you line up both timing marks on the distributor. (Im having a hard time finding it in the FSM atm but i believe the s13 tells you to set it this way)
this is totally wrong and will retard your ignition timing 1 tooth
set your timing right the first try and line the timing mark up with the dowel pin on the distributor gear (the dowel pin next to the timing mark)
iirc this is how the S14 fsm says to set timing
i use this trick a lot and today for shits and giggles i tried setting it to the timing marks and my motor would only puff and poof. then i used the trick advanced it one tooth and bam fired up after 1 crank
hope this helps somebody
The Game
you lose haha
kyral is offline   Reply With Quote
Old 07-11-2018, 12:14 AM   #2
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Uhhh the fsm tells you to line it up to the dowel. Same as SR cas install.
Old 07-11-2018, 07:13 PM   #3
kyral
kyral's Avatar
you wouldn't happen to know which chapter that's in, in the s13 ka manual?
I just posted this cause everyone seems to have the damndest time starting their KA's
The Game
you lose haha
