Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 05-03-2013, 08:09 AM   #31
Import Revival
Import Revival is an unknown quantity at this point
SR20DET S13 Power Steering Pump - 120.00 Shipped
Import Revival is offline   Reply With Quote
Old 05-03-2013, 12:20 PM   #32
Import Revival
SR20DET Power Steering Bracket - 55.00 Shipped
Old 05-03-2013, 05:57 PM   #33
jdms13scala
jdms13scala's Avatar
jdms13scala is an unknown quantity at this point
If you find any other power steering pumps. PM me please
jdms13scala is offline   Reply With Quote
Old 05-03-2013, 08:00 PM   #34
Import Revival
PM Sent - check your inbox.
Old 05-06-2013, 06:27 AM   #35
Import Revival
SR20DET Valve Cover - 95.00 Shipped.
Old 05-06-2013, 06:56 AM   #36
Import Revival
R32 Skyline 30MM (296MM Rotor Diameter) -
245.00
Shipped
Z32 Aluminum 30MM
225.00 Shipped
Set #1
Z32 Aluminum 30MM
225.00 Shipped
Set #2
Z32 30MM Iron Calipers
215.00 Shipped
Set#1
Description:
All Sets are Fully Loaded with used pads, shims, pins and fasteners. All rubber boots are intact.
If you have any further questions or concerns, feel free to PM for further details and inquiries.
Thank you
J.
Old 05-06-2013, 01:30 PM   #37
Import Revival
S14 / R33 Skyline OEM Rear Lower Control Arms AND Ball-joints - 120.00 Shipped
Description: This set of OEM S14/R33 Lower Control Arms are in excellent condition. The bushings are healthy and the Ball-joints are intact.
Old 05-07-2013, 11:32 AM   #38
Import Revival
Greddy Profec E-01 - Brand New
415.00 Shipped
Old 05-13-2013, 10:35 AM   #39
Import Revival
S13 Silvia Corner Lights
120.00 Shipped
Description: These Amber S13 Silvia Corner lights are in excellent condition. All tabs are intact, and the lenses are in very good to excellent condition. Normal wear and tear is expected. These lights are as described, and as pictured.
Old 05-13-2013, 10:37 AM   #40
Import Revival
S13 Silvia Headlights
250.00
Description: These OEM S13 Headlights are in excellent condition. All tabs are intact, and the lenses are in very good to excellent condition. Normal wear and tear is expected. These lights are as described, and as pictured.
Old 05-14-2013, 07:17 AM   #41
Import Revival
SR20DET 370CC Injectors
135.00 Shipped and Paypalled.
Description: These OEM SR20DET S13/4 370CC Fuel Injectors are functioning as they should, and have come from a clean-running SR20DET, imported directly from Japan, housed, here, in North America, and are in very good condition.
This does come with the Fuel Rail and Fuel Pressure Regulator.
Old 05-14-2013, 01:00 PM   #42
Import Revival
SR20DET CAS - Cam-Angle Sensor -
100.00 Shipped
Old 05-15-2013, 06:20 AM   #43
Import Revival
OEM S14 5-Lug Conversion
300.00
Description: These are Genuine S14 Front Spindles with OEM 5-Lug Hubs along with Rear Z32/R32 OEM 5-Lug Hubs with Anchor Bolt Insert should you decide to opt for an EBrake assembly in the rear.
N.B. If you are running S13 Front Lower Control Arms, please make sure to press in S14 Front Lower Control Arm Balljoints with these spindles.
Old 05-18-2013, 02:17 AM   #44
willianmiao
willianmiao is an unknown quantity at this point
cam angel
i want you sr20det cam angel how can i pay them?
willianmiao is offline   Reply With Quote
Old 05-19-2013, 05:19 PM   #45
Import Revival
Old 05-19-2013, 05:46 PM   #46
Import Revival
Old 05-19-2013, 08:04 PM   #47
Import Revival
Genuine OEM Silvia S13 Front Fenders
450.00 Shipped
Description Below
Description: The Fenders are in very good condition - one lip is slightly scraped in a little and needs to be massaged, but any competent body man will be able to fix that properly. All mounting points line up, and everywhere else is in excellent condition.
Old 05-20-2013, 09:48 PM   #48
Import Revival
Silvia S13 Front Fenders - Sold, thank you.
Set # 2 coming shortly.
Old 05-22-2013, 09:50 PM   #49
frankies1390
frankies1390 is an unknown quantity at this point
ok so how much for power steering pump shipped sr20det with bracket if you have one
frankies1390 is offline   Reply With Quote
Old 05-22-2013, 09:57 PM   #50
frankies1390
oh nevermind,pricey for used pump and bracket.... thanks anyway
Old 05-22-2013, 09:59 PM   #51
Import Revival
I did not even give you a price, are you speaking to yourself?
For everyone else - Silvia Fenders Set #2 pictures coming tomorrow.
Old 05-22-2013, 11:23 PM   #52
frankies1390
i didnt wanna look like "that guy"... so i re-read the power steering pump section and it was $120 for the pump then $55 for bracket, i just need the pump. So to restart the question do you have the power steering pump only, i dont need the pulley either if it helps?
Old 07-09-2013, 02:45 PM   #53
b4l
b4l's Avatar
b4l is an unknown quantity at this point
Nice part list
b4l is offline   Reply With Quote
