Old 08-27-2014, 10:34 AM   #1
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
s13 Sr20 injectors stuck open
Ok guys I need help, I'm having a very similar problem to this guy here: http://forums.nicoclub.com/injector-...p-t317319.html
And I'm not sure what the problem is. I took off the fuel rail and turned the car to the "on" position and gas is shooting out of injector #1 and #4.
My motor is a stock redtop sr20det just completely rebuilt and hasn't ran yet.
Any help is appreciated. I did search but most threads yielded no results.
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 08-27-2014, 12:38 PM   #2
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
check o rings
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 08-27-2014, 01:38 PM   #3
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
If the same thing happens with the injectors unplugged, it's probably leaking around the O-rings. If it only happens when the injectors are plugged in, check the wiring from the injectors to the ECU. If they are shorted to ground, the injectors will stay open all the time.
OnTheChip is offline   Reply With Quote
Old 08-27-2014, 01:43 PM   #4
coupesallday!
Trader Rating: (18)
Hey man thanks, I'm going to try that now
Old 08-27-2014, 01:57 PM   #5
coupesallday!
Trader Rating: (18)
It does it when the plugs are unplugged so I'm going to plug them in and see. Also nothing was coming out of #2 and #3
Old 08-27-2014, 05:06 PM   #6
wawazat8402
wawazat8402 is an unknown quantity at this point
Send a message via AIM to wawazat8402
Like the others said, check the orings. Do NOT replace with rubber orings, they need to be viton or something fuel safe. OEMs use viton.
wawazat8402 is offline   Reply With Quote
Old 08-27-2014, 05:36 PM   #7
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Just to piggy back on most of the replies, MAKE SURE, your O-rings aren't pinched to the point where they're either broken or separated.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 08-27-2014, 09:01 PM   #8
coupesallday!
Trader Rating: (18)
Two injectors were bad but I have a feeling it's not the o rings it might be the connection from the ecu.
