Old 11-17-2022, 09:14 AM   #1
thom
thom is an unknown quantity at this point
R200 diff assembly question
Hello guys,
I m in the process of changing the 2 bearings in the pinion in my r200 diff so i hopefully stop a whinning sound i have only on deceleration.
My problem is that by trying to torque the pinion nut any number more than 60-70nm it gets very stiff and doesnt turn at all! The manual says 190 to 290nm for this nut !
I really dont understand why since the bearings (Koyo) i got where the same part number and the pinion shims where put back as they where before.
Any suggestions ?
https://i.imgur.com/eZ2kb2w.png
thom is offline   Reply With Quote
Old 11-18-2022, 12:27 PM   #2
AKADriver
AKADriver's Avatar
That would seem to mean that the tapered spacer is bottoming out. Maybe the new bearings require different shims?
Old 11-20-2022, 11:15 AM   #3
thom
Unhappy
I thought of that but it doest make sense since part numbers are the same and i measured them before installation.
After watching some videos of r200 assemlby i saw that people tighten this nut by "experience" and turning to see how it feels , not loose but also not very tight.
https://youtu.be/0IYOyurW4DY?t=779
This is what i did also and after 2-3 miles everything sounded fine but once i reached high speed (50-60) something began to sound very bad and had to drive back super slow. It sounds like the small bearing on the pinion destroyed.
I checked backlash when i installed the diff and it seemed ok but i dont know what went wrong i have to disassemble again..
Old 11-29-2022, 04:02 AM   #4
thom
Sooo.. .. false alarm.
The small bearing under the seal had wrong shape even though all dimensions where the same , and it came loose. My fault didnt see that the guy sent me wrong part number. Bought the correct one and everything ok.
Still dont undestand why nissan say to torque it 19 to 30kg.
I tighten it until it felt turning good without binding and after driving for 1-2 hours no problem at all , no strange sounds or anything. We'll see hot it goes !
