Old 01-08-2017, 07:49 PM   #20671
derass
There's an optional cold pipe to use the GReddy IM with an S13 FMIC kit.
Old 01-08-2017, 09:35 PM   #20672
cbcm2435
cbcm2435's Avatar
cbcm2435 is an unknown quantity at this point
What size are the bolts that attach the fan shroud to the radiator for a s13 sr?
Sent from my Z963VL using Tapatalk
cbcm2435 is offline   Reply With Quote
Old 01-08-2017, 10:45 PM   #20673
Habibi240
Habibi240's Avatar
Habibi240 is an unknown quantity at this point
Originally Posted by Habibi240 View Post
SR20DET IGNITION TIMING
Im in need of help. I would like to know every component that would alter setting ignition timing.
Took my car in to a known shop and had it gone over but in the amount of time he had he couldn't find the root cause.
mechanical timing is set perfect
s13 harmonic balancer on s14 block (only difference between s13/14 crank pulley is ribs for ps pump) timing marks are the same. so no issue there
zero boost leak
plugs gapped @ 30
370 injectors oem fpr
enthalpy tuned ecu and he told me to run 15*btc of course
when timing is set @ 15*btc it bogs and backfires
but when its slightly advanced it revs happy and runs great.
to get it set @ 15*btc the CAS was clocked all the way right
it should be in the middle of the adjustment window im aware of so its right around the middle now and it runs fine .
what should i look into changing ? only thing we could think of is water temp sensor and CAS?
Help me Im refusing to drive my car
Habibi240 is offline   Reply With Quote
Old 01-08-2017, 11:47 PM   #20674
cbcm2435
cbcm2435's Avatar
Is your CAS set right with the cam? Where are you putting the clamp for the signal for the timing light?
Old 01-09-2017, 10:45 AM   #20675
Nickvas81
Nickvas81 is an unknown quantity at this point
Zenki foglight replacement lenses
I'm looking to repair or replace the lenses my fog lights which are cracked and missed pieces. I understand that an easy fix would be to just find used foglights (since they are no longer produced), but i dont know if it is the cheapest.
I've done quite a bit of searching for replacement lenses but did find a company that produces or sells them. Has anyone else found these?
Thanks.
Nickvas81 is offline   Reply With Quote
Old 01-10-2017, 02:42 PM   #20676
JrDarknes
JrDarknes's Avatar
JrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud of
Anyone own or has owned a circuit sports or p2m fan controller? Just want to to know what color the display is. Aiming for nothing but red for my interior.
JrDarknes is offline   Reply With Quote
Old 01-10-2017, 02:59 PM   #20677
bmar19
bmar19 is an unknown quantity at this point
It's red display
Sent from my LGMS631 using Tapatalk
bmar19 is offline   Reply With Quote
Old 01-10-2017, 03:29 PM   #20678
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Thanks.
Best option is probably finding a set with broken housings but good lenses and merge them.
Old 01-12-2017, 01:18 PM   #20679
jared420sx
jared420sx's Avatar
jared420sx is on the path to ruinjared420sx is on the path to ruin
Opinions on kits that would look good accompanied with koguchi overs?
Gt1 is alright. Trying to figure out another option if i went with them.
jared420sx is offline   Reply With Quote
Old 01-12-2017, 01:43 PM   #20680
mau5trap
mau5trap's Avatar
mau5trap is an unknown quantity at this point
Send a message via AIM to mau5trap
Anyone know where I can get an adapter like this that's not "brass"
http://www.autometer.com/1-8-npt-to-...-pressure.html
mau5trap is offline   Reply With Quote
Old 01-12-2017, 01:49 PM   #20681
kashira kureijii
kashira kureijii's Avatar
kashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-known
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
I bought a pretty cool one off ebay that has both 1/8npt and 1/8 bspt so u can use your aftermarket op gauge and the idiot light in the cluster i dunno
https://www.ebay.com/itm/131836884304
Originally Posted by bigs View Post
Just get a big sticker that says "copyright infringement"
kashira kureijii is offline   Reply With Quote
Old 01-12-2017, 01:50 PM   #20682
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
http://www.jegs.com/i/Earls/361/968698/10002/-1
Old 01-12-2017, 09:19 PM   #20683
mau5trap
mau5trap's Avatar
Originally Posted by e1_griego View Post
Thanks guys!
Old 01-12-2017, 11:54 PM   #20684
zo0d
zo0d's Avatar
zo0d is on a distinguished road
Trying to replace the wiper linkage on my S14. The entire bolt keeps spinning when I try to losen the nut. There is no room to grab it from underneath with pliers. Will I need to cut or drill the bolts/nuts out? Thanks
zo0d is offline   Reply With Quote
Old 01-13-2017, 12:11 PM   #20685
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
I've searched online and there are a lot of discussions about the final drives but not a solid answer that I am looking for.
Are all r200 diff final drive the same and can be swapped out? I'm looking into gathering the z33/g35 diff and axles and wondering if I can swap out the final drive for a 4.6 FD from an xterra.
instagram
1on1 is offline   Reply With Quote
Old 01-13-2017, 01:44 PM   #20686
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
try penetrate oil, maybe an impact driver, all else fails, cut it off.
VNG704 is offline   Reply With Quote
Old 01-13-2017, 11:07 PM   #20687
mau5trap
mau5trap's Avatar
KA24DE Oil Pump Question:
Would it better to just buy a whole new Complete Cover Timing Chain Assembly....
Or just replace the Oil Pump Gear + Oil Pump Valve Relief Assembly, and it'll be good as new?
thanks in advance.
Old 01-14-2017, 02:02 PM   #20688
chingon
chingon is an unknown quantity at this point
Q45 DIFF (97) into s13
A few questions, I have s13 pumpkin and q45 pumpkin (97)
I want q45 gears. Can I swap gear sets w/o issue (heard something about pinion spacers being required)? (I have s15 lsd going in so I know about bolt differences)
Can I swap input flanges between them?
If I keep q45 flange, will it rub against sway bar?
chingon is offline   Reply With Quote
Old 01-16-2017, 11:03 AM   #20689
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
anybody running r32 gtr brakes on their s14, and wouldn't mind me bugging you with questions?
just picked up a set while i was in JP for a bit
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 01-16-2017, 02:18 PM   #20690
1on1
1on1's Avatar
No experience but from reading this thread you need the correct rotors for the front and the rears are identical to z32 + can use z32 ebrake system:
http://www.240sxforums.com/forums/s1...ml#post1691905
instagram
Old 01-16-2017, 02:53 PM   #20691
STEEZxIT
STEEZxIT's Avatar
thank you, good info! i remember reading that elsewhere as well.
i had also found this thread with some good info;
http://zilvia.net/f/showthread.php?t=117194
just didn't want to bump it due to it's age and it being unlikely that the posting members would still be active on here, over a decade later. (though i did pm one out of optimism.)
more specifically, does anyone know if the set up is the same with z32 rear brakes, if you still need to run the entire drum assembly? i don't know where i came under the impression that you could simply bolt them up the way the stock brakes are configured on the s14 and still have a working ebrake.
@dangerdamian
Old 01-16-2017, 03:04 PM   #20692
e1_griego
e1_griego's Avatar
Trader Rating: (24)
R32 and z32 are the same in the back, so yes, you need the drum ebrake if you want it to work.
Old 01-18-2017, 11:12 PM   #20693
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
m6 x 1.0
Does anyone know where I can get that "cup holder" for 96+ s14 center consoles? It's literally just a flat piece of plastic that inserts into the slits that the 96+ center consoles have on them. I use to see them everywhere, now no amount of google searching will bring them up.
Old 01-18-2017, 11:18 PM   #20694
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
This maybe?
http://zilvia.net/f/showthread.php?t=639693
lunchmeat is offline   Reply With Quote
Old 01-18-2017, 11:18 PM   #20695
Hoffman5982
Trader Rating: (25)
m6 x 1.0
Old 01-19-2017, 04:39 AM   #20696
I'm Redline
I'm Redline's Avatar
Originally Posted by Hoffman5982 View Post
m6 x 1.0
http://www.ebay.com/itm/S14-1994-199...9Uxfwj&vxp=mtr
My work in progress...
Old 01-19-2017, 01:28 PM   #20697
Hoffman5982
Trader Rating: (25)
Sorry for the double post. And no, this is actually what I was talking about
http://www.frsport.com/Nissan-96931-..._p_770010.html
Old 01-19-2017, 02:09 PM   #20698
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
I just made one out of abs plastic for mines lol
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 01-19-2017, 05:27 PM   #20699
juhd
juhd is an unknown quantity at this point
are q45 brake calipers able to clear wheels with low disk/super low disk faces without a spacer?
Instagram:@juhd_
juhd is offline   Reply With Quote
Old 01-19-2017, 10:42 PM   #20700
DailySX
DailySX is an unknown quantity at this point
I have a bit of an odd/silly question: Does it matter what type of bolt I use to replace the old rusted/rounded ones? As in, can I just drop by a local Homedepot and get what I need? Or are the screws and bolts on the 240 "special" in anyway (plating/grade/etc.)?
It shouldn't matter too much, right?
DailySX is offline   Reply With Quote
