02-07-2016, 09:07 PM | #19141 | |
Trader Rating: (31)
Feedback Score: 31 reviews
I figured, I just wasn't sure if 5cc would make a huge difference. I saw the five-O in enjuku. I know dwerks are drilled OEM and that makes me a little nervous as I need reliability on them. Just ordered some P2M injectors Last edited by mr.nismo.; 02-08-2016 at 12:43 AM.. |
02-07-2016, 10:20 PM | #19142 |
Trader Rating: (31)
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
Has anyone heard of private works? This is inside my ECU.
Sent from my iPhone using Tapatalk Last edited by mr.nismo.; 02-08-2016 at 01:46 AM.. |
02-08-2016, 02:53 PM | #19146 |
can someone tell me what brand and model tire this is? I am looking for a stretch just like this for some rays wheels I have.
9.5j 215/40/18 original link: http://www.tyrestretch.com/9.5-215-4...-215-40-R18-4/ thank you in advance. sorry, I am not able to figure it out by the tread pattern, I assume someone here can tell me. |
02-09-2016, 09:04 AM | #19147 |
Did a boost leak test:
Filled intake system with shots of compressed air through small nipple on an intake tube w/a cap Used soap/water mixed and found the injector grommets bubbling/hissing (still, even after I removed fuel rail, tweeked to ensure all injectors sat flush, and used a little RTV) However, I'm wondering if that's just going to be the weakest point for air to escape, and the intake valves on those ports could of been closed when I did the test. They seem to be "sealing" while engine is running, pulling about 18 In. Hg @ idle. (JWT S4 cams) Any thoughts here? |
02-10-2016, 08:40 AM | #19148 | |
I would say Yokos or hankooks http://www.discounttiredirect.com/di...ca&exposed=brd |
02-10-2016, 11:42 AM | #19150 | |
I will keep looking into it. although I will probably just end up with federals (for cost), cause ive spent more than I wanted to on wheels. |
02-11-2016, 07:28 AM | #19152 | |
I may be off since I'm not sure what a "bm44" BMC is, just pointing out my Kouki has 15/16" stock. |
02-11-2016, 10:22 AM | #19155 | |
I got mine at Advance. Just make sure that the person selects the right trim for your car (Base, SE, LE) because unlike 95% of parts, the trim DOES make a difference for S14 wheel studs. |
02-11-2016, 11:05 AM | #19156 | |
From the info Ive seen I thought theres only 2 different ones for all S14: Front & rear, same thread pitch (12x1.25mm), same length (40mm), but different knurl specs (front knurl = 14.3 mm; rear knurl = 13.0 mm) |
02-11-2016, 11:20 AM | #19157 |
Question to all the suspension/coilovers nerds
What do you guys think about 8k/6k swift springs with helper springs for a s14? I'm looking for a versatile spring rate for street/drift/track/grip SET UP. The s14 is bone stock at the moment. (I do plan on running 17s and doing a 1jz swap in the near distant future).
02-11-2016, 11:40 AM | #19159 |
The 4 & 5-lug have different knurls. First ones I got didn't fit. Went back and noticed that base and SE had different part numbers.
02-11-2016, 11:59 AM | #19160 |
02-11-2016, 06:29 PM | #19162 |
Anybody know if i can run the s14 sr20 turbo inlet on my t28 (on an s13 sr) as opposed to using my s13 inlet with a clocking adapter...?
(Talking about the elbow inlet, not the actual intake pipe) |
02-11-2016, 07:17 PM | #19163 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
if i remember correctly, the S14 intake pipe is a totally different shape than the S13 intake pipe for the SRs. i have one at home, ill try to check when i get in tonight...
02-11-2016, 07:35 PM | #19164 |
Theyre for sure different, but can i use it on an s14 turbo that's going in an s13?
Right now im using clocking adapters, but if i can just use the s14 inlet, im going to get on. Mainly for the fact that it has the crankcase fitting for the hose on it. If youre not using the one you have, can i buy it from you? |
02-11-2016, 10:27 PM | #19167 |
I've been going through the Lighting Thread and the OneVia thread and I can't find a solid answer.
It's 2016. Is there a way to get GOOD light output out of an S13 Coupe? I don't want to blind other drivers and I'm not sure I want to doa front end swap. I've owned a converted S13 before and the light output sucked then with Triples too. I kind of want to keep my pop-ups, but I also want HID's. I'm moderately familiar with retrofits, but not with pop-ups. What can I do thats not insanely pricey and won't murder oncoming traffic? |
02-12-2016, 08:11 AM | #19168 | |
http://www.gtr.co.uk/forum/152950-privateworks-ecu.html |
02-12-2016, 08:13 AM | #19169 | |
Trader Rating: (24)
Feedback Score: 24 reviews
