Old 11-02-2010, 01:04 PM   #3271
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Originally Posted by kalypso123 View Post
ABS brake master cylinder... if i don't plan on actually using abs on my s13, are there any concerns with using one?
ABS master cylinder only has two outlets, one for the front and one for the rear. from there it goes to the ABS unit and the outputs of that go to their respective brake calipers. if you try and use the ABS master cylinder without the ABS unit then one of your front calipers wont be hooked up. you need to find a non-ABS master with three outlets.
Old 11-02-2010, 04:14 PM   #3272
bmoses
bmoses is an unknown quantity at this point
Originally Posted by MANOlOS14 View Post
So i will be getting an s13 soon (hopefully), im planning on doing a full tune-up plus:
• 4-2-1 Headers
• straight pipe from headers
• magnecor wires
• ngk plugs
• advance timing couple of degress (did this to my previous s14 and was more responsive)
• reroute air intake with cone filter
• cut springs (yes i know how dangerous, bad this is but IT will be temporarily)
• short shifter
Just for starters, eventually i will do a ka-t setup but to begin just this, what do you guys think? Any cheap power increases?
I wouldn't use anything other than OEM ignition parts, set the gap towards the wide end of the spec. I'd go 2.5", no bigger on the exhaust, straight thru is fine. Advancing the dizzy is good. relocate battery, or move somehow and have a short ram intake from the the battery tray. My KA responded well to this. You have butterflies in your intake, not sure about those. Remove mechanical clutch fan. You should be able to rely totally on your electric fan, assuming S13's have an electric fan.
bmoses is offline   Reply With Quote
Old 11-02-2010, 04:48 PM   #3273
MANOlOS14
MANOlOS14's Avatar
MANOlOS14 is an unknown quantity at this point
true bout the springs ^^^^^ as far as headers it'll b a long time before turbo charging it so thats y..
MANOlOS14 is offline   Reply With Quote
Old 11-02-2010, 10:00 PM   #3274
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
Can i weld my coils where the gas is? Or will the chamber get hot and explode?
jacobs13 is offline   Reply With Quote
Old 11-03-2010, 03:19 PM   #3275
Urbanfer
Urbanfer is an unknown quantity at this point
Send a message via AIM to Urbanfer
anyone know where i can get 91 exhaust manifold with egr pipe/vavle? pm plz real urgent
Urbanfer is offline   Reply With Quote
Old 11-03-2010, 03:37 PM   #3276
Corbic
Corbic's Avatar
Will a S13 sub frame bolt into a S14? What about complete front suspension? (cross-member, coils, power brace, knuckles et al).
Old 11-03-2010, 05:40 PM   #3277
heavenboundkevin
heavenboundkevin's Avatar
heavenboundkevin is an unknown quantity at this point
randomly i hear this 'click' coming from the lower right part of my dash. if im in the drivers sear i hear it from the area of the headlight retract button. it sounds like a tick of a clock. when it happens it might happen, then again 3 seconds later, then nothing.
anybody have any ideas what this could be? its not something stupid like my keys rattling.
car is a stock 91 s13 coupe with stock ka24de.
Originally Posted by rat240 View Post
sick bro .... hella jdm foshow i love haters
heavenboundkevin is offline   Reply With Quote
Old 11-04-2010, 12:05 AM   #3278
icedsole
icedsole's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Originally Posted by icedsole View Post
A quick inquiry, is part that the actual clutch fan connects to the pully with the same for SR and KA?
I installed my clutch fan with a "KA" piece onto my sr, and it didnt seem to go into the fan shroud that far. i thought maybe
it could be that i have a stock radiator, but id just like to make sure.
................. wooo
@pwrmves14
Old 11-04-2010, 02:28 AM   #3279
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
What kind of hoses are people using for this GT oil drain? Power steering or fuel hose maybe???
http://www.treadstoneperformance.com...65-0-thumb.jpg
Luvs2slide is offline   Reply With Quote
Old 11-04-2010, 10:10 AM   #3280
DFWZenki
DFWZenki's Avatar
DFWZenki is an unknown quantity at this point
SR Intake manifolds??
Just curious, Are the S13 SR Intake manifolds and S14 SR Intake Manifolds interchangable? Wondering if an S14 would work on an S13 Sr20det? Is either one better? Thanks.
DFWZenki is offline   Reply With Quote
Old 11-04-2010, 08:18 PM   #3281
s14freak93901
s14freak93901's Avatar
s14freak93901 can only hope to improve
s13 SR and S14 SR intake manifolds are not interchangeable.
s14freak93901 is offline   Reply With Quote
Old 11-04-2010, 08:24 PM   #3282
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
will T28 oil return hose work for T25?
REVIEW
killer240 is offline   Reply With Quote
Old 11-04-2010, 08:52 PM   #3283
fckillerbee
fckillerbee's Avatar
sounds like something is turning on, are you running ac/heater? cd player maybe....doest it do it when your not driving? like car sitting on, or car sitting off.
Old 11-04-2010, 09:57 PM   #3284
uLmighty
uLmighty's Avatar
uLmighty is an unknown quantity at this point
Send a message via AIM to uLmighty
ok, dont flame on me or anything but what does "fucking classy" sticker mean relating to jdm or cars in general?
uLmighty is offline   Reply With Quote
Old 11-04-2010, 10:39 PM   #3285
fckillerbee
please delete your post, and google each word separate. a dictionary will help your answer.
fucking is an exaggeration in this text. and classy is like fancy. like opening a door for a pretty lady....
watch some james bond movies...he's all about class.
and yes, i'm aware of the language barrier.
Old 11-04-2010, 11:36 PM   #3286
uLmighty
uLmighty's Avatar
lol. i knew what each word meant, i jst thought it would mean something different but thanks lol
Old 11-04-2010, 11:53 PM   #3287
jdmjap808
jdmjap808's Avatar
jdmjap808 is an unknown quantity at this point
has anyone painted their interior before and what kind of vinyl paint works the best?
jdmjap808 is offline   Reply With Quote
Old 11-05-2010, 06:03 AM   #3288
240sx123$
240sx123$ is an unknown quantity at this point
Just about every Civic and Neon in "the scene" did it back in '97. If you wanna go that route, go for it- to each their own. Just fair warning- you WILL be laughed at.
240sx123$ is offline   Reply With Quote
Old 11-05-2010, 06:32 AM   #3289
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
rear subframe - not easily, and it's a waste of time.
front suspension - yes, if you drill the lower mounting holes bigger to fit s14 bolts or don't drill and use sleeves for the 13 bolts
cross member - yes
power brace - no
c72c is offline   Reply With Quote
Old 11-05-2010, 07:38 AM   #3290
Corbic
Corbic's Avatar
cross member - yes
power brace - no
Thanks. I found you can swap a S14 sub into a S13, so I figure the reverse is true. Any idea on coilovers?
I'm asking because I have a newly rebuilt S13, needing only cosmetics, but I've been thinking of going to a S14....right after I should my conversion harness for pennies, figures.
Old 11-05-2010, 09:57 AM   #3291
c72c
c72c's Avatar
Trader Rating: (25)
Thanks. I found you can swap a S14 sub into a S13, so I figure the reverse I'd true. Any idea on coilovers?
I'm asking because I have a newly rebuilt S13, needing only cosmetics, but I've been thing of going to a S14....right after I should my conversion harness for pennies, figures.
By front suspension, i was referring to the coil overs.
you can swap a 14 s/f to a 13 and vice versa, but you need offset bushings to do it right.
people swap a 14 s/f to a 13 because of the way the rear end works on the 14 and it's a little wider.
when you launch a 13, the rear wheels camber in during the squat whereas a 14, the rear wheels tuck straight up leaving more rubber in contact with the road. so swapping a 13 s/f into a 14 would be more of a 'downgrade'.
Old 11-05-2010, 10:30 AM   #3292
madd ocx
madd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymore
quick question, are the front lower control arms for the s13 and s14 the same or is there a difference? i heard the s14 arms for are longer, but dont how true it is..
madd ocx is offline   Reply With Quote
Old 11-05-2010, 10:35 AM   #3293
sickrbs14
sickrbs14's Avatar
sickrbs14 is an unknown quantity at this point
is s13 sr20s obd1
sickrbs14 is offline   Reply With Quote
Old 11-05-2010, 04:14 PM   #3294
Corbic
Corbic's Avatar
Thanks!
I figured it would be a downgrade since I've found the S14 into S13 stuff.
My sub is stripped and recoated, PBM bushings, welded diff, poly bushings in knuckles and arms. It'd be a pain to do all that all over again.
Old 11-05-2010, 04:43 PM   #3295
jdmjap808
jdmjap808's Avatar
No no no.. Not some crazy color?! I want to change it from the rare navy blue to black. Thats not outrageous but just simple. Any certain brands for vinyl paints?
Old 11-05-2010, 05:20 PM   #3296
heavenboundkevin
no its not anything like that, not running a/c or heat, i have no dc player. It only happens when car is running, im not sure about it happening with the car just "on" i.e. engine not running.
Old 11-05-2010, 06:20 PM   #3297
Urbanfer
need help leaking oil pan any ideas example like get a new one silicon? etc thanks
Old 11-05-2010, 06:43 PM   #3298
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
Do KA Single Cam Spark plug wires work on a Dual Cam KA?
jdm2191 is offline   Reply With Quote
Old 11-06-2010, 11:37 AM   #3299
TheQ
TheQ's Avatar
TheQ is an unknown quantity at this point
My crank pulley gave out on me today...am looking for a used one off another engine. Do you know if a crank pulley off of any year of KA24DE will work?
TheQ is offline   Reply With Quote
Old 11-06-2010, 11:51 AM   #3300
srstan
srstan's Avatar
srstan is an unknown quantity at this point
it should work fine
srstan is offline   Reply With Quote
