10-18-2014, 01:18 PM | #1 |
RB26DETT 240sx Convertible
For sale: 1993 240sx Convertible with RB26DETT
Bluffton, SC Does not run at the moment, needs turbos. Here's the back story. Drove this car as a weekend toy for the last 4+ years never raced or drifted believe it or not, it ran slightly rich and misfired. Finally diaged it and found leaking turbo to exhaust manifold gasket causing a lean o2 reading which richened the fuel mixture (P.S. I'm a BMW master tech not self proclaimed mechanic). Removed turbos and found one leaking but not terribly. Decided to rebuild turbos with steel wheels and 360* thrust washer kits. Sent new turbo internals and intake wheels out for balancing by G-POP shop and prior to re-assembly I found multiple cracks in wastegate sealing surfaces of both exhaust turbo housings. Reached the point where I'm ready to sell it instead of buying new housing or turbos. I am in no hurry to sell and I am very upfront about everything that has been done, needs and personal repair suggestions. Would be a perfect if you're planning to go large single but I never wanted to do that so you'd have a good amount of fresh parts to sell. $8,000 OBO buyer responsible for transportation, PM me for more info, interest Etc. 330hp to the wheels on the dyno untuned at 14.5psi on stock twin turbos with a leaking turbo exhaust gasket. It's been in my garage for the last year while I worked on it, can send more current pictures of it with the turbos off. R32 GTR RB26DETT with RB25 Trans Will come with new and used parts and also comes with a new top frame, top, rear window, headliner, and cables. Buyer can have SR20 parts as well if interested (Block, cylinder head Etc.) Partial Parts list (Not everything) Have all receipts too: Kaaz 1.5 LSD and Kaaz 80w90 oil Custom Intercooler piping New RB25 Crank Pulley Wiring Specialties Custom Wiring Harness Greddy weighted shift knob New RB25 Nismo transmission mount New R33 GTS-T Crossmember Syko Motor mounts Nistune software board and consult cable 2 12” Mishimoto Cooling fans Mishimoto Black M line intercooler Mishimoto transmission cooler (for P/S cooler) HKS Type 1 turbo timer and harness HKS limited edition Black SSQV BOV New RB N1 water pump New RB N1 Oil pump Energy suspension bushings kit Apexi intake kit New Nissan RB26 resistor pack (no longer available) Custom made Driveshaft Shop Driveshaft for Syko mount kit Greddy coolant swirl tank Brembo Z32 OE brake rotors DIF Front brake conversion lines Z32 Aluminum 30mm 4 piston front brakes (powder coated black and rebuilt seal kit) S14 single large piston rear brakes Greddy timing belt HKS limited edition oil cap Blitz Nur Spec-R exhaust Walbro 255 fuel pump Nissan Gasket kit (Not all gaskets used) Ichiba 5 lug hub conversion front and rear R32 GTR 16x8 forged aluminum wheels Nismo Thermostat New OEM drive belts Z32 Fuel filter Tein inner and outer tierods Tein Superdrift Coilovers S14 Mishimoto Radiator Carbon Fiber RB26 timing and coil covers from Asustralia Battery Relocation and Engine bay terminals added Modified RB26 AWD oil pan for sway bar and removed front diff and welded up axle holes Dakota Digital Speedo and Tach converters Autometer Boost, water temp, oil temp, and oil pressure gauges Steering rack Empi boots Circuit Sports Coolant expansion tank Modified Samco coolant hoses Nismo RB25 Short shifter Gauge pillar mount Earls oil cooler Greddy thermostatic oil filter housing Tanabe Front and rear sway bars Wideband O2 and gauge Nissan NX Digital Cluster wired and installed Z31 BMC Apexi GT modified downpipe
1993 240sx Vert With RB26DETT 2001 BMW 530i (DD) |
10-21-2014, 09:58 PM | #8 |
rb26 stock turbo? i have my old set ill sell you is you need exhaust housings. let me know then get you car running and you can get more or even sell quicker
10-29-2014, 02:13 AM | #15 |
Can attest that this motor is wired up proper. New owner should not have any electrical gremlins.
Good luck with sale!
Visit our Website - Check out our Blog - Like us on Facebook - Follow us on Instagram |
