10-11-2018, 01:54 PM | #1 |
1992 S13.5 LS Turbo
Please read entire listing before commenting.
1992 Nissan 240sx Exterior: S15 Front Origin Bumper S13.5 Front Fenders Fiberglass Origin 40mm Wide S15 Vented Seibon Hood S15 Headlights Rear 50mm Fiberglass Origin Over Fenders Origin Side Skirts S13 Origin Rear Bumper Nismo Carbon Fiber Wing Seibon Carbon Fiber Hatch w/Lexan Glass New Metallic Blue Paint Smoked Tail Lights HID Hi/Low 6k Headlights Square Wheels 18x9.5+12mm 4x114.3 Pattern Nexen Tires Front 245/30/18 Rear 275/30/18 Aluminum 25mm Wheel Spacers w/Extended Studs CX Racing Coilovers Megan Racing Rear Upper Control Arms Megan Racing Lower Traction Rods Interior: Formula Drift Spec Rollcage Vinyl Wrapped Custom Aluminum Door Panels Dash with vent holes filled (except defrost top vent) vinyl wrapped Autometer Gauges: Speedometer, Tach, Voltage, Oil Pres., Coolant Temp. Boost AEM Uego Wideband Black vinyl racing seats RJS 4 pt. racing harness Turbosmart Boost Controller Grant Steering Wheel w/Quick Release 15 Gallon Fuel Cell New Battery Engine built by Mike Lough Racing: 5.3 LM7 Cast Block Bored to 5.7 364 LQ4 Crankshaft w/Polished Journals 6.125 Callies Compstar Rods King XP LSX Bearings Rods, Main, Cam Bearings New GM Cam Retainer Plate New GM LS9 Head Gaskets New GM Lifter Trays New GM LS7 Hydraulic Roller Lifters Wiseco Forged Pistons w/Rings Block Water Jackets Filled Balanced Rotating Assembly Engine Break-in on Stand Brian Penn Racing Oil Internal Oiling Mods for Forced Induction ARP Main Studs Comp Camshaft Custom Grind New GM Pushrods .080 wall New GM Double Roller Timing Set Holley Sniper Intake Manifold Holley Sniper Fuel Rails FIC 95# Injectors Fast 102mm Throttle Body Holley Dominator Fuel Pumps Holley Fuel Pressure Regulator MSD Plug Wires Hooker Ceramic Turbo Headers Custom Exhaust Turbo Cross Over Pipes 2.25" into Y @ 2.5" into turbo inlet @ 3" Knife Edged Turbo Inlet All Piping Ceramic Coated and Heat Wrapped Borg Warner S480 Turbo 1.32 A/R Turbo Exhaust Housing Machined from 5" v-band to 4" v-band Turbo Guard Grill 4an Turbo Feed line with Summit Check Valve 10an Turbo Drain Line with Summic Check Valve Custom Aluminum Turbo Oil Sump Turbowerx Exapump Oil Pump CX Racing 1000hp Intercooler Griffin Aluminum Radiator Electric Fan Tial MV-R Wastegate Tial Q BOV Mishimoto Stainless T Bolt Clamps Mishimoto Couplers New 180 Degree Thermostat 8an Fuel Feed / Return Lines New LS1 Power Steering Pump New LM7 5.3 Silverado Alternator ICT Billet High Mount Accessory Bracket Kit Summit Racing Valley Cover and Knock Sensor Delete Earls Steam Tube Kit All Fittings and lines from Fragola PSI Conversions Wiring Harness and PCM Custom Turbo Mount Turbo Blanket Custom Plate Motor Mount Wilwood Clutch Master Cylinder Chase Bays Clutch Master Cylinder Line Kit Chase Bays Hydro Hand Brake (Not Installed) Sikky Clutch Adapter Plate Monster Stage 5 Clutch Steel Resurfaced flywheel Built T-56 Transmission with Viper Ratios Hawk Racing Billet Shifter Custom Transmission Mount Sonnax Slip yoke Custom Aluminum Driveshaft Tomei Technical Trax 2-Way Differential Car makes over 1000whp on Q16 and 20psi (Could do it on Pump gas) Street tuned at 93 Octane and 10 PSI at 622whp. Super Conservative Made 485whp N/A Entertaining Trade Offers. Cash is King. Looking for 20k obo. Don't like the price keep moving. This car is a 6 year build with lots of time and money invested. No Heat or AC at the moment. No known issues. Probably 1000 Miles on the car since built. Everything replaced. Clean Title in Warrior, Alabama. Watch the video for walk around and to hear run. https://youtu.be/NZYiTLsNU4o Serious inquiries please message me for further details or pictures of specifics. https://youtu.be/rM7e4A50Y4k Last edited by cpl dozier; 10-17-2018 at 10:08 AM.. |
