Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Electronics
Old 03-18-2016, 11:29 AM   #1
Enjuku Racing
Trader Rating: (29)
Enjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to behold
Feedback Score: 29 reviews
Send a message via AIM to Enjuku Racing
Enjuku Racing - Wiring Specialties VH45DE Wiring Harness
Wiring Specialties VH45DE Wiring Harness for Nissan 240SX S13 - PRO SERIES
Starting at $649.00
This Wiring Specialties Pro Series Wiring Harness includes the engine and transmission harnesses for a Nissan 240sx S13 with a VH45DE engine swap. It was developed in house on an actual VH45DE engine and comes tucked for a clean finish. The harnesses is designed as a one-piece unit with integrated OEM COIL, Injector and transmission harnesses for clean install.
Engine: Infiniti Q45 VH45
Any VH45 from 1990-1995 Infiniti Q45
WILL work on 1996 model with adjustments
Chassis: S13 240SX
Any S13 240sx manufactured in 1989-1994 (Including the Convertible and ABS cars)
PRO-SERIES HARNESS FEATURES
Plug and Play
Significantly lighter than a factory harness
NO CORE HARNESS or additional wiring required
REQUIRES use of NEW style Ignitor Chips
REQUIRES use of OEM Coils
Available with New or Early style injector connectors
Available with New or Early style CAS and TPS connections
Constructed using OEM connectors and seals
Made with high temp TXL wire (-40C to +125C operating temperature) with adhesive shrink tubing
Wrapped in lightweight nylon loom with -94C to +257C operating temperature
Includes a charge harness and improved grounds
Fully tested after production for an easy plug-and-play replacement
Turn Key ENGINE START Guarantee
Tech support for our customers 7 days a week.
PRO-SERIES HARNESS INCLUDES
One-piece design with integrated Coil, Injector and transmission connectors
Alternator charge cable.
Nissan Diagnostics connector.
Power and dash interface connectors.
Retains factory A/C,speedometer, tachometer, engine temperature gauge, oil pressure sensor, alternator charge light, reverse lights and wipers.
Our Pro-Series is ideal for those looking for the best aesthetics, weight savings and reliability. Completely replace your old harness and forget about electrical gremlins
Office: 352-241-8399 / 1-888-SR20DET (772-0338)
YouTube.com/c/EnjukuRacingParts
http://www.enjukuracing.com
[email protected]
Enjuku Racing is offline   Reply With Quote
