07-12-2013, 12:06 PM | #1 |
KA24 to 350z/Z33 Adapter plates in stock!
You asked and we delivered(finally!).
After months of testing, fitting, R&D, CAD, laserz and so many other things we have the KA plate available for sale. Here is what you can expect: -Stronger gears -Better gearing -Smoother and more precise shifting -Newer transmissions -NO MORE TRANS FAILURES If you are familiar with our SR20/Z33 adapters then you know how awesome of a swap it is. After 100+ SR kits sold and installed worldwide we've heard nothing but good things about the Z33 transmission. Just take a look at the size comparison! SR AND KA 5SPD HAVE IDENTICAL GEAR SIZES As with our other adapters you will need a few things to complete the swap. -Adapter plate -Transmission mount -Driveshaft -Shortened shifter bracket -Modifying Z33 Bellhousing, The KA also requires some mods for the starter hood to clear. -Stainless steel clutch line. There are many vendors out there who sell these. Pricing: Just the plate and hardware is $430 shipped Additionally other mods are available in stages depending on what you want to pay for. Bellhousing Machining. Not just any machine shop can do this because of the size of the bellhousing. $100 +ship Shifter modification. You send in your shifter and it gets modified then sent back to you. $125 +ship Transmission crossmember. You can retain the original rubber mount(aftermarket mounts will also work). $100 +ship If you need further proof of (destructive) testing. Here is a video of Chris Forsberg trying his best to kill a transmission. After going through a few 5spd stock transmission he called us up and we worked on getting him a KA adapter. Contact: Feel free to contact me through; PM [email protected] five two zero 444-4415 Thanks, George
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all |
07-12-2013, 05:42 PM | #3 | |
It's also cheaper than constantly replacing stock transmissions when they blow up. I'd rather have something that works and will get me through an event vs wasting all that money when my trans blows on the 1st practice lap.
07-12-2013, 06:20 PM | #5 | |
The transmission is bigger and longer than the stock one by a lot. We shorten the bracket as much as possible but depending on your motor mounts and how far they set the motor back, you might need to notch the cutout.
07-12-2013, 08:07 PM | #7 |
Trader Rating: (58)
Feedback Score: 58 reviews
Aweome stuff George!
07-13-2013, 01:52 AM | #8 |
im very interested/* i definitely want one*
i was trying to get around to calling JWT, that was the only kit i knew of... for a price quote for theirs Last edited by white-s13coupe; 07-13-2013 at 04:35 AM.. Reason: ? |
07-13-2013, 08:25 AM | #9 |
still requires maching off the notch on the trans for starter to line up? is it ok to use ka starter or will different starter be needed.
s14 kouki ka-t |
07-13-2013, 10:02 AM | #10 | ||
PM me for wholesale options. Thanks! Thanks Cody! Quote:
Yes, the starter hood will interfere with the bellhousing. It's a small and quick mod. You will continue using the KA starter.
07-14-2013, 07:28 PM | #11 |
Do ya just have to chop the little cone that surrounds the starter gear? or is the mod in the bell housing? If i delivered the trans to you guys would the charges be the same as quoted, except without shipping? (considering that im in AZ and i believe you guys are as well?)
07-15-2013, 10:48 PM | #12 |
Here's a question, I don't have the shifter bracket but i have everything else. Can I buy one from you already shortened? I did the whole vq swap but principle remains the same. I kinda wish this kit was available years ago, I might have kept the KA. Anyways, It's hard to come across that bracket by itself.
07-16-2013, 11:52 AM | #13 | ||
08-19-2013, 11:54 AM | #16 |
Driveshaft is $320 for steel and $390 for alumn.
Machining numbers are given upon purchase.
