Old 07-04-2008, 04:50 PM   #1
papi13
papi13's Avatar
papi13 is on the path to ruinpapi13 is on the path to ruin
SR20DET fuel problem HELP!!!!
okay im new to this forum and i never had this problem but i was drivin home from work one day and i hit a big dip at about 70mph.....after about 5sec. i hit the dip my car just shut off......the car has spark but the fuel pump wont turn back on.....i checked the fuel pump(walbro255lph) it was fine even when i put a whole another one it incl. sending unit, it still wont turn on.....i checked all the fuses and replaced the relays.....so please help me
and if i have to hardwire the fuel pump, how do i do it because on the sending unit there is one black wire(ground) and like 4 colored wires and idk which ones which
papi13 is offline   Reply With Quote
Old 07-04-2008, 09:47 PM   #2
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
Blk(-) and Brown(+Red) are the wires once you Have the Fuel Sender Out of the tank.
The Wires for the pump if using the Pins on the Harness I'm not 100% sure of,..but I think its Blk/Yellow stripe and another one...oh well you'll see it when its out.Follow them to the wires that are Conecting to the Pump Itself.
Grab a 12v Drill batt and try them.See if it turns on but only check for a sec.
may have a Harness issue where it plugs into the trunk plug part.
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 08-06-2008, 01:19 AM   #3
phatkatsquad
phatkatsquad is making his/her stupidity well-knownphatkatsquad is making his/her stupidity well-knownphatkatsquad is making his/her stupidity well-knownphatkatsquad is making his/her stupidity well-knownphatkatsquad is making his/her stupidity well-known
yeah you should wat mr lady said then if it has 12 volts then its probably ground that came lose. that shit happen to me once i hit a bumb and the damn ground came loose from the chassis just tightened it up and she pured again lol. if this helps let me know
phatkatsquad is offline   Reply With Quote
