Old 05-23-2010, 04:53 AM   #61
Om1kron
Om1kron's Avatar
looks good.
Wayne Edwards
https://om1kron.blogspot.com
Old 05-23-2010, 12:30 PM   #62
EnjoiNISMO
EnjoiNISMO's Avatar
EnjoiNISMO is an unknown quantity at this point
Looks good jserman.
Damn hondas.
EnjoiNISMO is offline   Reply With Quote
Old 05-23-2010, 02:57 PM   #63
GSXRJJordan
GSXRJJordan's Avatar
Some of the Hondas are great, but it seems like they put an inordinate amount of effort into it to not get rid of the fusebox and battery. Same goes with our cars.
Originally Posted by Om1kron View Post
There are plenty of places to buy them online and the pins, etc. But they're going to run you about 300+ dollars I believe they're like 180 dollars a side. And they're not really designed for multiple connects/disconnects.
I can get you guys the connectors you need, you have to be very careful when ordering them because you're ordering from a military supplier, where all they care about is a part number... there's probably 10 characteristics that make up a part number, and if you jumble one or two you now have a couple very expensive paperweights.
About the number of connects/disconnects ~ these connectors are usually rated for a certain number, after which if they were used in a military application, they'd have to be replaced. Most people will be fine, but don't go reconnecting it every 5 minutes for people at a car show or something.
Old 05-24-2010, 08:07 AM   #64
kyles1988
kyles1988's Avatar
kyles1988 is an unknown quantity at this point
My old civic
My friend Toby's engine bay...I guess he's doing a real tuck/shave sooner or later.
kyles1988 is offline   Reply With Quote
Old 05-24-2010, 08:56 AM   #65
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
^ that is one of my favourite S-Chassis engine bays.
So clean. So much attention to detail.
IIIXziuR is offline   Reply With Quote
Old 05-24-2010, 09:14 AM   #66
S13coupeRB25DET
S13coupeRB25DET is an unknown quantity at this point
Originally Posted by kyles1988 View Post
My old civic
Thats like the sickest sr20det ive seen in along time.
S13coupeRB25DET is offline   Reply With Quote
Old 05-28-2010, 12:06 PM   #67
Envy2343
Envy2343's Avatar
Envy2343 is an unknown quantity at this point
damn i have lots of work to do
Envy2343 is offline   Reply With Quote
Old 05-28-2010, 06:40 PM   #68
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Is it alright to have the power steering reservoir located this low, below the pump?
Some declare that the pump needs to be gravity fed, while others say the reservoir can be below the pump, as long as there are no major leaks in the system.
Old 05-28-2010, 08:20 PM   #69
GSXRJJordan
It's certainly not ideal, but yes there's a fair amount of vacuum created by the pump and I never had p/s problems with my reservoir mounted below the pump on the SR or RB25. What it does mean is that every time you start the car, it has to re-bleed itself, which is not great for your pump (they like to be lubricated and cooled by fluid all the time) but not the end of the world.
In short, not recommended, but not a real hazard either.
Old 05-28-2010, 08:45 PM   #70
White Comet
White Comet's Avatar
White Comet is making a name for him/her selfWhite Comet is making a name for him/her self
what i did for mine that looks nicer and is a little more ideal is mount it closer to the firewall between the strut tower and the master cylinder. i'll have to put up a pic of it there, i really like it
buy my type x stuff
White Comet is offline   Reply With Quote
Old 05-28-2010, 08:55 PM   #71
Matej
Trader Rating: (39)
Great information, thank you. I will keep it there for now. If my pump ever goes out, I shall relocate it elsewhere.
Old 05-28-2010, 09:21 PM   #72
Om1kron
Om1kron's Avatar
just in case you're not a premie.
Wayne Edwards
Old 05-30-2010, 01:17 AM   #73
D C
D C is an unknown quantity at this point
We use the multipin connectors on our camera systems, some of them going on 15+ years strong of being connected and disconnected a few times a month at least.
As long as they are pinned properly, and you aren't a hamfisted retard when connecting them (pretty hard to mess up anyway) then there shouldn't be a problem.
D C is offline   Reply With Quote
Old 06-01-2010, 08:19 AM   #74
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
looks like a hastle just to top off your p/s fluids
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 06-01-2010, 10:44 AM   #75
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
Those ideas for relocating the P/S reservoir look pretty cool.
What kind of rubber hose should one use when doing this?
Old 06-02-2010, 02:18 AM   #76
yingiang
yingiang's Avatar
yingiang is making a name for him/her selfyingiang is making a name for him/her selfyingiang is making a name for him/her self
damn theres alot of WIN in this thread. love the clean engine bay look
yingiang is offline   Reply With Quote
Old 06-02-2010, 02:28 AM   #77
Om1kron
Om1kron's Avatar
aeroquip push lock hose for the reservoir.
Wayne Edwards
Old 06-02-2010, 03:31 AM   #78
GSXRJJordan
The Aeroquip push-loc stuff is great, but any oil-safe rubber hose will work as well. Make sure there aren't any kinks.
5/8" (-10an) is what you want for reservoir to pump, 3/8" (-6an) is low pressure from the rack back to the reservoir.
Old 06-02-2010, 05:18 AM   #79
NiSilS14
NiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond repute
not mine but a cousin's. Pretty neat stuff.
NiSilS14 is offline   Reply With Quote
Old 06-02-2010, 05:37 AM   #80
White Comet
that sounds about right. i remember the one size was kinda hard to find. also, i used the the fitting from an s14 off the ps pump since its angled differently and works better for the relocation
buy my type x stuff
Old 06-03-2010, 09:24 PM   #81
stockbee
stockbee's Avatar
stockbee is an unknown quantity at this point
Send a message via AIM to stockbee
these look sick!
stockbee is offline   Reply With Quote
Old 06-04-2010, 12:17 PM   #82
kalypso123
(ノಠ益ಠ)ノ彡
nice to know
Old 06-04-2010, 12:33 PM   #83
TurboSE
TurboSE's Avatar
TurboSE is an unknown quantity at this point
I use a lot of weatherpack connector, not as factory looking as the ones above, but I like em.
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please.
TurboSE is offline   Reply With Quote
Old 06-04-2010, 03:11 PM   #84
GSXRJJordan
Weatherpacks are fantastic for big stuff (14ga, 12ga), and I use them for things like radiator fans and starter solenoids. The problem with a loose plastic connector like that though is insertion issues between the pins and sockets, and they're just physically too large.
Old 06-05-2010, 11:14 AM   #85
s142jzkillav10
s142jzkillav10's Avatar
s142jzkillav10 is an unknown quantity at this point
Send a message via MSN to s142jzkillav10
Very Very nice. I wanna do my tuck to show it off aswell.
S14 2JGt42/95SC300/92SC300/93SC300Want feedback look me up on Supraforums
s142jzkillav10 is offline   Reply With Quote
Old 06-05-2010, 12:06 PM   #86
White Comet
heres some pics of mine, the wire tuck is done, but the car isnt running so i'm trouble shooting and picking up a harness tomorrow, but it'll continue to look like that.
thats fully wired, every wire that'll ever be in there is.
the the engine wires are run through the ac hole
all the wires for the engine before anything else went in.
everything for the engine harness being cut to length and done up so we could see exactly what we could tuck.
pretty much how it looks now.
the body harness was shortened and run across the dash bar and only was need to run down the fenders was, like the headlights and turn signals. everything visible in the engine bay was wrapped in techflex and heatshrink.
buy my type x stuff
Old 06-17-2010, 04:12 PM   #87
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
Got my tucked brake line kit from chasebays for the s13!
And the LS1 millspec harness
WangonwWarrior is offline   Reply With Quote
Old 06-17-2010, 09:07 PM   #88
White Comet
very nice, how do you run the cb brake lines exactly?
buy my type x stuff
Old 06-17-2010, 09:19 PM   #89
Om1kron
Om1kron's Avatar
He can probably better explain than me. But I wouldn't run soft lines like that for my brakes. Regardless of what pressures they can withstand.
Wayne Edwards
Old 06-17-2010, 10:37 PM   #90
Ekin_s13
Ekin_s13 is an unknown quantity at this point
Ekin_s13 is offline   Reply With Quote
