01-22-2013, 11:18 AM | #64 |
Im looking for the wiring swap pinout for the late model s14sr20det kouki with the ecu code NA* im puttint into 95 240sx , and does it matter if i use auto chasis harness or manual chassis harness?
12-16-2013, 11:21 AM | #65 |
how many extra plugs will you have left over on the engine harness after everything is hooked up? I imagine most of us don't use AC, so that would be a plug, but i have 6 plugs left over using the engine harness that came with the s14sr20det.
07-22-2015, 06:53 PM | #66 |
this has been good help solved some of my problems. but what if im not running my whippers do i still need to change all this? im only running p/s. sucks because the chassy had a sr before and it was a mess and im cleaning it up. lmk thanks!
07-23-2015, 01:03 PM | #67 |
The year is 2015 and it should only take one to two days to do this swap. They are so common place now it isn't even a swap anymore, its more like an easy fix.
