11-04-2011, 05:27 PM | #61 | ||
I'll be at Simply clean with it tomorrow actually.
enjukuracing.com |
11-04-2011, 05:29 PM | #62 |
Trader Rating: (31)
Feedback Score: 31 reviews
holy shit man.
Mr.OEM. i love it. curious the total you've got in this thing. still blown away at the frame rails how perfect they are.
z-tERty-2 |
11-04-2011, 06:21 PM | #63 |
Clean as hell... Wish I had the money and patience to do something like this.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
11-04-2011, 07:35 PM | #64 |
Since I haven't posted anything about the motor, here we go.
For the motor I decided to stay with the Ka, I didn't wanna deal with getting a junk motor from an importer. The main reason is that I just like Ka Turbo, Torque is close to the same as horsepower yada yada.. It's just my opinion. Unfortunately I don't have as many photos as I would like to have with the motor build stuff, but this will suffice. Just as the chassis was, the motor and tranny went through a very thorough cleaning, then stripped down and completely rebuilt. After completely taking it down to the block, the crank, and head were sent to the machine shop. Polish/Bore Etc.. I just decided to a mild build on the motor, nothing ridiculous. I wanted the motor to be fun and somewhat reliable. After it got back from the machine shop I gave the block a fresh coat of gloss black. My engine builder mike dealt with assembling all the internals of the motor. Since I don't plan on going much over the 300 horsepower range I kept stock rods, now I regret this and wish I would have bought some Eagle rods just in case, oh well Went with some JE pistons, Clevite bearings, Bc valve springs and retainers, Cometic Head gasket, FiveO 550cc Injectors, Vibrant oil drain kit with AN fittings, ISIS Turbo manifold, ISIS 3871, ISIS O2 housing, OEM T2 Gasket, OEM 5 Bolt gasket, brand new timing chain and guides, Brand new OEM oil pump, Water pump, lower water neck, Valve cover gasket, Alternator, Starter, SPEC Stage 3 Plus clutch, RS ENTHALPY rom tune.. much more I've missed. onto the photos. Moving along quickly, we plopped the motor back into it's original home.
enjukuracing.com Last edited by Levan. B; 11-16-2011 at 10:45 PM.. |
11-04-2011, 07:36 PM | #65 | |
Yeah man! this car was taken care of quite well its whole life.
enjukuracing.com |
11-04-2011, 08:13 PM | #67 | |
First impressions right off, the quality of the turbo is definitely decent for the price. casting isn't flashy or anything but that is nothing of importance anyways. Oil feed inlet and drain look fine, the turbine wheel spins smooth for a journal bearing. Thing is, I've witnessed many of these turbos work very well on friends cars with no problems whatsoever, they spool quickly, and I know if anything happens to this turbo I have a great warranty on it. There will be no problem with sending the core back and receiving a brand new replacement. BUT, I do plan on going to a Garrett if i start having problems. I enjoy driving my car.
enjukuracing.com |
11-04-2011, 08:27 PM | #68 |
Back to the body for a bit.
As you've probably noticed on my old gold car, I had almost completed my OEM 180sx Kouki Aero, but due to QP damage i couldn't ever have my rear valences on. This car would get all of the OEM kouki aero from that car. Mocked up the side skirts and drilled all the holes out so that It could be mounted as it was from the factory, along with the front speed panels and spoiler. I had a professional remove the rear quarter windows for paint sake. Random shot of the build and my fathers LS1 Fd. Side skirts/speed panels mocked up: Rear valences chilling. Drilled the holes for the rear spoiler. After all the body panels were mocked up and ready for paint we continued to button up the engine bay and get it 100% driveable before it was sent off to paint. Started on the intercooler piping, and got a little crazy with my MAF and air filter placement. I'm worried about driving in the rain, but they will be isolated from the wheel with fender liner. Then I decided against using the OEM clutch fan, and purchased a SPAL fan controller and two 12" fans. Also had Mike weld a bracket to the oil catch tank so it could be bolted to the radiator fan shroud. Did a small wire tuck also, and went nuts with AN fittings and braided lines.
enjukuracing.com Last edited by Levan. B; 11-16-2011 at 10:58 PM.. |
11-05-2011, 04:20 AM | #72 |
Jurassic Park reference? I don't get it.
www.enjukuracing.com |
11-05-2011, 08:04 AM | #75 | |
11-05-2011, 09:16 AM | #78 | |
Trader Rating: (31)
ka-t for the win i love mine and dont regret it one bit. as long as the motor is built and you have the right parts. Keep up the great work man
Slip Gypsies Blog Quote:
11-05-2011, 09:40 AM | #79 |
This build is just gettong better and better , love the color. This build and treefishes' 180sx are some of my favorie, great attention to detail and the paint choice is awesome!
11-05-2011, 06:56 PM | #85 | ||||
Thanks! For sure, if I decide to get some more sweet parts I'll be sure to. Just gotta figure out what is next! haha.
enjukuracing.com |
11-06-2011, 04:18 AM | #88 |
I remember your Dad used to be pretty active in the 240sx scene about 10 yrs ago, no? PSI240sx is a real OG if I recall correctly and you couldn't have a better mentor to guide you through the build. He's built quite a few S-chassis in the past, if I recall!!
Keep up the good work!
**The atypical S-chassis enthusiast*** |
11-06-2011, 10:34 AM | #89 | |||
Thanks!
enjukuracing.com |
