Old 01-02-2020, 12:12 AM   #1
Dsmguy1993
Dsmguy1993 is an unknown quantity at this point
Please help with fuse box identification
Hi guys so I just rebuilt an sr gettin ready to put it in my 1989 240sx but before I do i wanted to put the car in accessory to make sure the windows roll down at least or I have some sign the car electronics work. Where would my positive cable connect to on the engine bay passenger side box? Also on the driver side ACC fuse box I think someone before me cut the ground wire off it.. ive attached pictures to make it easier if someone can help that would be much appreciated! Edit: I know the bigger of the two electrical eyelets on the engine bay passenger side box run to battery+, alternator +, and starter +, what would be the best way to fix that driver side ACC fuse box ground is my real question?
https://ibb.co/vjtsDFT
https://ibb.co/0Z4CrTS
https://ibb.co/VBCN2VZ
Dsmguy1993 is offline   Reply With Quote
Old 01-02-2020, 06:28 PM   #2
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
the larger gauge white wires are your 12v to fuse box
The Game
you lose haha
kyral is offline   Reply With Quote
Old 01-02-2020, 10:35 PM   #3
Dsmguy1993
Thank you kyral! I kinda figured it was just lookin at it for a while i already tested my wiring specialties interface harness that plugs right into the box and the box also has a connector for the Alternator charge harness ima wire it up after I quit being lazy and take the hood off.
Old 01-07-2020, 12:16 PM   #4
Dsmguy1993
I got the car to come onto accessory again just grounded the fuse box using sand paper hooked a battery up connected to the fuse box larger white wires connection and it works brake light switch is bad because brake lights stay on. Clock comes on dash lights come on still.
Old 01-08-2020, 04:58 PM   #5
kyral
kyral's Avatar
so is that a question? I cant really tell =(
The Game
you lose haha
Old 01-08-2020, 07:06 PM   #6
Dsmguy1993
Oh no question I just wanted to say I got my wiring figured out thanks for confirming the power wire was those two thick white wires leaving the fuse box.
