Old 12-11-2019, 07:52 AM   #1
Kaisen
Kaisen is an unknown quantity at this point
S14 starter clicks but doesn't turn over
Hi guys, so I've been encountering this issue recently where the starter clicks but then goes silent. The thing is it still manages to start sometimes. So I thought it might be the starter and I got it repaired with new solenoid switch and carbon, etc. Installed it and it still doesn't manage to turn over. I've tried cleaning the battery contact points, tightening the clamps and all the grounds. My ignition has been modified by the previous owner and it has a power on switch and a start button. Could the start buttom be faulty? Is that even possible since it's just a contact point for 2 wires? I've read that there is a starter relay? Some says it's in the engine bay, some says it's in the passenger side panel. Any insight would be very much appreciated. It's a 1994 zenki s14 sr20det manual trans. I don't have to step on the clutch when starting the car as well
Kaisen is offline   Reply With Quote
Old 12-11-2019, 09:26 AM   #2
S14rebuild
Did u test the battery?
Check for weak/bad relay
Old 12-11-2019, 05:44 PM   #3
Kaisen
Battery is tested in healthy condition.
Where are these relays located? And how many relays are there for the starter?
Old 12-11-2019, 07:57 PM   #4
S14rebuild
There is 1 relay, located in engine fuse box
Down load the fsm, and pull up the starting system. Very simple wiring diagram to follow
Old 12-12-2019, 07:56 AM   #5
duballstar37
duballstar37's Avatar
duballstar37 is on the path to ruinduballstar37 is on the path to ruinduballstar37 is on the path to ruin
-Check starter relay. Bypass relay by jumping the circuit and see if it works
-Inspect your aftermarket ignition switch, replace or "hot wire" to bypass
-Check connection between lower engine harness and body harness (look for corrosion or anything out of the ordinary)
Was the car originally automatic? Or did you jump the clutch interlock?
PS. You will kill your battery pretty quickly by continuously trying to start the car unsuccessfully. Make sure you have a well charged battery. You can also kill your new starter if you just let it crank. I would cycle your attempts while you troubleshoot.
P.A.T.T.
duballstar37 is offline   Reply With Quote
Old 12-12-2019, 08:10 AM   #6
S14rebuild
Sounds like a connection issuse, ether loose, bad contact/corrision somewhere
Old 12-12-2019, 06:08 PM   #7
Kaisen
Would you happen to know where this starter relay is located? The car came with a manual transmission, I've googled a picture of the clutch interlock relay but I don't see any of that relay anywhere, it could have been bypassed by the previous owner as well.
I'm guessing it's a weak connection somewhere for the starting issues. The car has been able to start these days, so I'll probably just leave it for now lol
