12-29-2017, 10:07 AM | #1 |
KA24de long block
I recently bought an s13 that originally had a single cam and the previous owner swapped it with supposedly a s14 ka. Swapped over all the s13 dual cam stuff like the intake manifold ignitor or coil pack and the distributor and I acquired and s13 dual can harness.
My question is how do i know its really an s14 ka. I need to replace a freeze plug that looks like it had been leaking and I also want to build the bottom end for boost. Dont want to buy the wrong pistons unless all the dual cam pistons are the same size. |
12-29-2017, 10:29 AM | #2 |
The location of the valve cover bolts is the easiest way to tell. The s14 has a bolt in the middle of the back lip of the engine, and the s13 has three bolts on the top of the valve cover.
12-29-2017, 11:20 AM | #3 |
The distributors are different. S14 has two plugs, S13 has one. Valve cover bolts are different. I believe an s14 only has 2 bolts in the top middle and s13 has 3.
Also, All DE pistons are the same. |
