Old 04-06-2012, 09:32 AM   #1
Zenki_cb
Zenki_cb's Avatar
Zenki_cb is an unknown quantity at this point
Question 5 lug rotor to 4 lug.
Hey what's up Zilvia was wondering if anyone knows where I could go to get my 5 lug rotors drilled out to 4 lug. I stay in 909 area code. I know someone but in Santa Ana I really don't want to drive out there unless I can't find anyone near me. Thanks ahead of time.
Zenki_cb is offline   Reply With Quote
Old 04-06-2012, 09:43 AM   #2
DJZ
DJZ's Avatar
DJZ is an unknown quantity at this point
Drilled out to 4 lug?? WTF?????? Why not just get the 4 lug stuff?
DJZ is offline   Reply With Quote
Old 04-06-2012, 09:53 AM   #3
Zenki_cb
Zenki_cb's Avatar
Because I already have the 5 lug rotors. It will be a while until I can buy the 5 lug conversion.
Old 04-06-2012, 10:02 AM   #4
Edwin562
Edwin562's Avatar
then just buy 4 lug rotors...
Old 04-06-2012, 10:07 AM   #5
vas570sx
vas570sx's Avatar
vas570sx is an unknown quantity at this point
to the OP, ive done this multiple times. its very simple. just lay the 4 lug and 5 lug rotors face to face, tack a nut and bolt that are the same size as your lug stud and bolt the 2 rotors together through one of the bolt holes and line up the hub holes.
Then, all you have to do is get a drill bit thats the same size as your lug stud and drill out the 3 remaining holes.
BAM! 4 lug z32 rotors.
vas570sx is offline   Reply With Quote
Old 04-06-2012, 10:09 AM   #6
510n
510n's Avatar
510n is an unknown quantity at this point
The easiest way, besides just buying 4 lug rotors is to use a drill press with a 1/2 inch drill bit.
510n is offline   Reply With Quote
Old 04-06-2012, 10:36 AM   #7
Zenki_cb
Zenki_cb's Avatar
Thanks guys appreciate the help.
Old 04-08-2012, 12:55 PM   #8
whiteboy-s13
whiteboy-s13 is an unknown quantity at this point
clarks has them for 12 bucks a rotor new
whiteboy-s13 is offline   Reply With Quote
Old 04-08-2012, 02:31 PM   #9
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Make sure you bevel the lug holes you drilled just a bit like the holes that are already in it. Will help cut down on cracking around the hole you drilled.
Also make sure you lube the drill bit as your drilling.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
4 lug, 5 lug, brakes, rotors
