Old 04-13-2014, 06:27 PM   #1
supradeluxe
supradeluxe is an unknown quantity at this point
HELP! Identify this bolt/pipe
Hi, today while installing a couple things I accidentally loosen this bolt attaching to this pipe that label "H" and as soon as the bolt was loosen air compress was shooting out and I immediately close the bolt. I want to know what is this bolt and pipe? And what is the air shooting out after I loosen it? Did I damage anything? Thanks for your help.
*picture is upside down*
Engine is stock ka24de, bolt and pipe is right next to intake.
supradeluxe is offline   Reply With Quote
Old 04-13-2014, 07:13 PM   #2
Def
That's your high pressure refrigerant line for your AC system. I'd put a little more R134a in from a can. Won't need much, but probably good to make sure it's charged well (run it for a minute full blast, get a can with one of those dummy gauges - connect it to the LOW pressure side, the other cap with an L on it, probably by the AC compressor).
But your car is fine as long as you closed it back up quickly and put a little more refrigerant in.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 04-13-2014, 07:38 PM   #3
supradeluxe
thanks alot for the help! appreciate it alot
