Old 01-07-2014, 07:38 AM   #1
kleenS14
kleenS14's Avatar
kleenS14 is an unknown quantity at this point
SR (S14)Power FC L-Jet, GT2876r, DOC Race Mani, R35 Sways and more
Alright time for some mid-winter cleaning. Email is [email protected], but I should be able to check back pretty often. Prices are obo plus shipping, but don't be ridiculous bc then I'll be ridiculous . Here we go......
Apexi Power FC L-Jetro (MAF Style) for S14 Sr2odet Zenki, with brand new OLED Commander. Never did end up using this ecu but did plug it into my harness to make sure everything powered up as it should, and it did of course. Commander doesn't have a single scratch on it. Price: sold
Garrett GT2876r with never used .86 a/r Swain coated (170$) turbine housing. Reason for selling, moved onto a completely different setup. Ran this turbo for about 1000 miles with a .64 housing and put down 348whp and 352wtq with respectable spool time and stock internals. Should be an easy 400whp with larger housing. Will include silicone coupler used for intake since its like 60$ from Vibrant, as well as DIF forged oil and water lines with all necessary fittings and oil restrictor. Can also include 14psi wastegate with bracket and heat shield if desired. Price: SOLD depending on what you want with it.
14psi wastegate for t25/28 with heat shield. Holds more boost than the HKS unit and is cheaper. Special heat shield included with t28 style bracket. Price SOLD.
DOC Race Bottom Mount T25 flange manifold. This thing is super beefy! Definitely the sturdiest bottom mount manifold I've ever seen. Nothing like those chinese bottom mounts out there. Believe me, this thing looks real nice in the engine bay. Btw, no those 2 studs in the flange aren't broken, just 2 missing and 2 in there. Ran this manifold with the GT2876r for about 1000 miles and loved it! These things are going for 700$ now, and worth every penny imo. Price SOLD and pretty firm on that one.
N62 300zx Maf. Short time of use, and it looks brand new. Screens are perfect and yes, its a real one not a copy. Comes with a wiring specialties adapter pig tail that's brand new. Price SOLD
Unknown brand of subframe collars. Price, shoot me an offer.
Ebay turbo outlet with fat 02. Worked just fine for me, no steering shaft problems. Price: 50$
OEM suction pipe with S14 MAF. Pretty self explanatory...Price: MAF IS SOLD, still have suction pipe
Rocker Arm Stoppers. I think they're Circuit Sports. Def. stainless because they haven't flaked apart or anything. Price: SOLD
Nismo Extended Studs. These are for an s14 hubs front and rear. Never used. Go for 100$ a set, ill take 150$ for both.
Nismo 555cc injectors with stock rail. Used for very only 1000 miles, and no broken pintle caps. Little guys go for 750$ on frsport, Ill take 400$
Nismo Super Single SR Clutch kit. Has a sprung Spec 6 puck in it and works great. I loved this clutch, but have moved onto a X 6 speed so can't use it anymore. Could benefit from a flywheel refinish but other than that in good shape, no cracking at all. These guys aren't cheap either, well over 1000$ new. Price: 350$
HKS Fuel Cut Defender. Not the prettiest thing but it did its job. Price SOLD
Wahlbro 255l in-line fuel pump with -6 an fittings and dynamat. Only have one of these two left but a good option if you need a little bump in flow volume. Price 70$
OS Giken Super Single Clutch Kit for SR. Well used setup but no cracks on friction plate or flywheel. Refinish the flywheel and maybe grab a new disc and youll be good to go. We know how expensive these kits are, so steal one for 200$.
Schroth 5 point cam lock harness. Expired FIA cert, but perfectly fine for street use. Cam works perfectly and harness is overall pretty damn clean. Price: 80$
Schroth 5 point button relase harness. Expired FIA cert as well but works just fine. Matches previously mentioned harness, just easier for your un-educated passenger to release lol. Price 50$
Radical (Willans) 6 point cam lock harness. Out of a Radical race car. Beefy ass harness with the super sweet Radical logo on it. Expired FIA, but a really nice harness. You're not going to find one of these anywhere short of stealing it from one of the race cars. Works perfectly. Wear what the pros wear! Price 120$
Stillen R35 GTR front and rear sway bars with hiem joint end-links. Know this isnt the target market for these, but worth a try. Comes with everything needed to install brackets, bushing, end links, bars. Nice set and costs 1000$ new. Let em go for 350$
kleenS14 is offline   Reply With Quote
Old 01-07-2014, 03:21 PM   #2
hks4life
hks4life is an unknown quantity at this point
how come the single disk dint work on the 6speed?
hks4life is offline   Reply With Quote
Old 01-07-2014, 04:30 PM   #3
Def
S15 SR clutches use a very thick flywheel with the pilot bushing integrated. Speaking of that, I have a nice Nismo coppermix S15 clutch I need to sell... thanks for reminding me.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 01-07-2014, 04:34 PM   #4
JayCastle
JayCastle is an unknown quantity at this point
how much for the wastegate shipped to 91204?
JayCastle is offline   Reply With Quote
Old 01-08-2014, 09:00 AM   #5
kleenS14
kleenS14's Avatar
Def is right. I was amazed at how much thicker the S15 flywheel was compared to the regular SR style. I stayed with the super coppermix though, just had to get a new one. Its a forgiving pressure plate. The old lady could whip it around with 4" heels on but she still bit hard when it came to it.
@JayCastle I currently have someone interested in the turbo setup, but if/when that doesn't pan out Ill get at you with a price.
Old 01-08-2014, 11:59 AM   #6
JayCastle
Kk sounds good, lmk
Old 01-08-2014, 01:23 PM   #7
KevinEdgar
KevinEdgar's Avatar
KevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to all
Damn good stuff and great prices, gotta pay my stupid cards off first...
http://milktea-man.com
KevinEdgar is offline   Reply With Quote
Old 01-08-2014, 02:13 PM   #8
kleenS14
kleenS14's Avatar
@KevinEdgar thanks man. Pay off that plastic and buy it all! Lol
Also am looking for a bare s14 block or blown up (not catastrophically of course) to get over to the machine shop since my main stud threads have been giving out after the line hone. Would be willing to trade for one.
Sent from my SCH-I545 using Tapatalk
Old 01-08-2014, 02:28 PM   #9
M374llic4
M374llic4 is an unknown quantity at this point
Send a message via AIM to M374llic4
Can I get that MAF off you please?
M374llic4 is offline   Reply With Quote
Old 01-08-2014, 02:57 PM   #10
kleenS14
kleenS14's Avatar
@m374llic4 you've got a pm sir
Old 01-09-2014, 02:23 PM   #11
kleenS14
kleenS14's Avatar
Turbo, lines, wastegate and manifold have been sold. Just working out details.
Everything else is still up for grabs
Old 01-10-2014, 11:38 AM   #12
kleenS14
kleenS14's Avatar
Quick update....
Turbo.....sold
Lines......sold
Wastegate.......sold
Manifold......sold
Waterneck......sold
S14 MAF.......sold
Rocker arm stoppers....sold
Everything else still available. Let's get the rest gone! :-)
Old 01-10-2014, 04:09 PM   #13
JayCastle
noooo! I really wanted that wastegate : [
By any chance do you have the name of the place or website you got it from?
Old 01-10-2014, 04:11 PM   #14
kleenS14
kleenS14's Avatar
@jaycastle Well don't get too upset yet, having trouble working out shipping details to Canada so it might be back on the table here soon, you'll be the first to know
Old 01-10-2014, 04:16 PM   #15
JayCastle
awesome haha thanks man
Old 01-10-2014, 10:22 PM   #16
s13kam
s13kam is an unknown quantity at this point
were the rocker arm stoppers part of that shipping fumble too? intrested in those, wastegate, and o2 elbow if you still have it all. paypal ready and would need them shipped
s13kam is offline   Reply With Quote
Old 01-11-2014, 01:19 PM   #17
kleenS14
kleenS14's Avatar
The rocker arm stoppers are sold, as well as the wastegate. The elbow with o2 is available. I'll have to update this thread. But @s13kam ill send you a pm to work out the details
Old 01-14-2014, 12:37 PM   #18
kleenS14
kleenS14's Avatar
Thread updated for sold items. Going well, lets clear out all this stuff. Ill be adding more shortly most likely.
Old 02-02-2014, 10:43 AM   #19
kleenS14
kleenS14's Avatar
Bump for hiv treatment banner at the bottom of tapatalk right now.
clutch, ecu, injectors, manifold, turbo
