Old 07-22-2014, 10:20 PM   #1
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
s13 SoCal: 1990 Nissan 240sx *SMOGGED* *CLEAN TITLE* *REGISTERED* 3500OBO
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
CAR IS SOLD
PICTURES ARE LEFT FOR HISTORICAL/PERSONAL REASONS.
GOOD BYE S-ChassiS WORLD!
MODIFICATION LIST[/CENTER]
Engine:
U12 ECU (socketed with 27SF512 EPROM) Consult plug added to ECU harness
NA3 Tune (requires 91oct)
Completely eliminated all a/c components in Engine Bay
Ford Tempo Dual Electrical Fan Conversion
Removed Fan Shroud
Removed Mechanical Clutch Fan
Timing, Idle, Fuel Mixture Set Accordingly via Factory Service Manual
Replaced
-Fuel Filter
-PCV Valve
-ECT Sensor
-Starter
Cleaned MAF
Cleaned Throttle Body
Adjusted Throttle Cable Tension
Extra Engine and Battery Grounding Points
Installed Battery Terminal Covers
Installed OEM battery hold down
Nismo Thermostat
Nismo Radiator Cap
OEM Water Pump
ISIS Radiator Hoses
Mishimoto Radiator
70/30 +WW (distilled water/coolant +water wetter)
Gladman Air Diversion Plate
Brand New Crankshaft rear main seal
Lighweight Power Steering pump pulley
Lighweight Water pump pulley
DriveTrain
S14 Low Mileage 5-Speed Transmission (Approx 120k miles from donor)
Viscous Limited Slip Differntial (JDM s14 4.14FD)
Amsoil Manual Transmission & Transaxle Gear Lube 75W-90
Stock shifter with solid metal bushing
Stainless Steel Clutch Line
Removed Clutch Dampner
Adjusted Clutch Pedal Free Play
Removed Cruise Control Components
F1-Racing Light Weight Steel Flywheel
Exedy OEM Clutch
Brand new OEM Throw-Out bearing carrier and retainer springs
Nismo Transmission Mount
Suspension
Stance GR+ Coilovers
Front
Strut Tower Bar
Tein Inner and Outer Tie-Rods w/o steering angle spacer
Brand NEW OEM Lower Control Arms
Energy Suspension Bushings
-Tension Control Rods
-Sway Bar
-Steering Rack
Nismo Powerbrace
Solid Steering Column Bushing
REAR
Strut Tower Bar
-Upper Control Arms
-Traction Arms
-Toe Arms
-Lower Control Arms
-Sway Bar
Moog Ball Joins - Lower Control Arms(w/zirc greese fitting)
OEM JDM 180sx Rear Sway bar
RPSport Subframe Support Braces (RARE)
Brakes
Agency Power Stainless Steel Brake Lines w/teflon coating
Brembo Front and Rear Slotted Rotors OEM size
PBR XBG Front and Rear Brake Pads
Removed Front and Rear Dust Shields
Replaced brake pedal stopper with brand new OEM
Interior
Removed All Rear Interior Panels
Removed Rear Seats
Removed Ceiling Panels
Removed All Pillar Panels
Removed Carpet
Removed MOST floor board tar mat
Removed Stereo and Speakers (have since installed front speakers, no
headunit included)
Removed Antenna
Removed Spare Tire Jack
Removed Spare Tire
Removed Sun Visors
Removed Automatic Seat Belt Control Module
Installed female consult connector
Sprayed floor board flat black
Mini Cabin Harness Wire Tuck
S13 Coupe SE Digital Guage Cluster
RED Led bulb conversion - Guage Cluster
Boss Steering Wheel Hub
Personal Neo Grinta Poly 350mm Steering Wheel w/Yellow Stiching
Leather Shift Boot w/red stiching
leather E-Brake Boot w/red stiching
S14 Manual Seat Belt Conversion
Replaced Cracked Dash with Flawless dash
Replaced Steering Column w/working ignition tumbler
Brand New ignition switch
Sparco Sprint (fia expired)
Sparco Slider
Wedge Engineering DriverSide Seat Bracket
_saitoSPL industries C-Pillar Bar
Immaculate OEM Passenger Seat
LED Key Ring Light (Amber)
Installed brand new oem clutch pedal stopper
OEM 240sx floor mats
Exterior
Removed Front Wheel Well Covers
OEM JDM Chuki 180sx Side Skirts
OEM JDM Zenki amber/clear front turn signals.
Wangan Wing
OEM Rear Mudflaps
S13 Pignose Front Lip
Removed Windshield Washer Resevoir
H4 Headlight Conversion
Manual Door Conversion
Replaced Broken Moon Roof
Removed Rear Wind Shield Wiper
Nostril Cut-Outs on Pignose Bumper
Powered by Max Gold Vented Hood Spacers
OEM JDM 180sx Windows Visors
Primered/Flat Black entire Exterior
Tomei 15x6.5 +22
Hartge 15x6.5 +25
-7MM slip on wheel spacers all around
S13 SE Alloy Wheels(2 for spares, crap tires)
SPARE PARTS:
Stock Chipped ECU with stock tune, installed for smog purposes
Nissan Consult adapter, software provided upon request (no support given)
A few fuel injectors
Alternator, the current one has a slipping belt due to pulley damage
(could not for the life of me remove the nut holding the pulley)
3 spare KA24E ECUs
1992 Nissan 240sx KA24DE factory service manual
several random/misc parts
WheelsDirty
for sale, ka24e, rhs13, s13, zenki
