11-19-2016, 07:13 PM | #1 |
s14 sr20det with s13 stuff
I have an s13 sr20det in my car right now and all the matching harnesses/ecu to go with it. My question is that if I were to buy an s14 sr20det, can I still use the same harness and ecu as my s13 stuff? I know ecu wise the s14 ecu only works with the s14 harness and s13 ecu works with the s13 harness. I'm strictly talking s14 engine with s13 harness and ecu.
11-20-2016, 09:42 AM | #6 |
Oh, you mean. right if i do it once, but, i got money? Got it makes perfect nonsense. I can afford to do it stupidly. So, why not?
Sent from my LG-H631 using Tapatalk
11-20-2016, 12:47 PM | #7 |
I was just asking because I have an s13 sr20 already in my s13 with and ecu tune. Just asking if it was possible to do with s13 harness and ecu on s14 sr20 but if it's not I was planning on doing everything the right way anyways. Just checking so I didn't have to go spend extra money.
11-20-2016, 12:57 PM | #8 |
Mechanically I don't think there would be in issue. They only thing I can think of that would be an issue is S13 and S14 SR Idle Air Controller Valve plugs are different and the S13 SR harnesss doesn't have a plug for the S14 SR VTC. But save your self some headaches and go with a S14 SR Harness
11-20-2016, 06:01 PM | #9 | |
11-20-2016, 08:20 PM | #10 | |
11-24-2016, 08:02 AM | #11 | |
Could you repin your harness and make some of the s14 stuff work? Short answer. yes, and thats where it gets stupid. That part isn't even the hard part. The hard part is figuring out if you're going to get an s14 ecu and harness or repin it back to stock or just trash it etc. Because it runs like crap. You could just sell to some unsuspecting noob, who comes to zilvia! Your options are endless.
11-29-2016, 03:28 AM | #14 |
if you don't engage the vtc the gear will empty of oil and start to knock as if the engine has a rod knock.
dont try mixing harnesses, engines or computers. those parts are very cheap and there is no excuse, even for a poor person like myself. It is literally the reason why I have a 240 to begin with, because that is the only car that I can afford to do right with $0 income. It really throws me in a loop when people tell me they can't afford to do a basic swapped 240 correctly. You must have a negative income, or underpants gnomes are stealing your salt. |
