Old 02-26-2013, 08:17 PM   #1
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
SR SR20 Parts for Sale (Stock and Performance parts!)
Hey guys, just have way too many parts laying around that I don't need 3 spares of. Let me know if you're interested in any of the following parts!
Attached a few pics of some of the parts, but lets be honest, we all know what they look like, and my perfect trader rating should speak for the rest. This stuff isn't junk, nor does it need to sell as it's really not in the way.
Aftermarket parts/Performance Parts:
Stock Wastegate with External Waste gate provision (Tial 38mm and MVS available) 160 dollars (If you give me your stock manifold I'll take 40 dollars off that price)
Air Conditioning Conversion kits, for KA compressors on SR20 engines - 70 to 110 dollars depending on engine, and setup
Quest Alternator Conversion brackets, allows the use of 115 or 125 alternators on SR20 engine - 55 dollars
Tomei Gen 1 Oil Pan: 225 dollars
Exterior Parts:
S14 Navan Fog Lamps (projector) - 60 bucks
Internal Parts:
S13 Dipstick Tube with Dipstick - 30 dollars
S13 Water Neck outlet with tapped 1/8" NPT port (for a guage) - 20 dollars
S13 Redtop Injector Rail (no caps) - 25 bucks
SR Coil Packs (3 total) - 20 a piece
SR20 Waterpump - 25 dollars (2 of them)
SR20 Upper Oil Pan - 45 dollars
SR20 DET Pistons (No Rods) - 20 dollars a piston, 75 for all
SR20 Rear Main Seal Housing and Seal (2 of them) - 30 dollars
SR20 Cam Gears - 30 dollars a set
The gears are the same. The CAS drive can be included if needed. Great upgrade for those with S14 engines not wanting to deal with the VTC
SR20 Timing Chain - 30 dollars
Misc:
Engine Removal Hooks (6 sets) - 25 a set Fit great, makes for easy removal of the engine.
Suspension:
Z32 Rear Aluminum Uprights with ES Poly Bushings Installed: 75 dollars
S14 Rear Traction Arms with Poly Bushing Installed, and braced/welded - 25 dollars.
Old 03-04-2013, 08:19 AM   #2
b4l
b4l's Avatar
b4l is an unknown quantity at this point
Air Conditioning Conversion kits when i get my sr swap im going to buy one bro i live in the desert and this is a must
b4l is offline   Reply With Quote
Old 03-04-2013, 12:40 PM   #3
codyace
codyace's Avatar
Trader Rating: (58)
El Paso gets hot! I spent some time in Ft Bliss, I could only imagine being there for longer than I was, to darn hot!
Old 03-04-2013, 02:48 PM   #4
b4l
b4l's Avatar
Yup my front clip should be here by friday I hope
Old 03-04-2013, 06:32 PM   #5
codyace
codyace's Avatar
Trader Rating: (58)
Cool! If you want to purchase them directly, check out my website CodyAce SR20 Air Conditioning Bracket follow the purchase page for a direct paypal link
air conditioning, alternator, pistons, uprights
