12-12-2013, 06:34 PM | #6061 | |
you need longer tie rods. you can get these at any local parts store. look back over the last few pages. there's lots of info in here about which inners and outers are longer than stock. to get you off on the right foot: i have PBM forged knuckles and +56mm LCAs. i'm using A32 maxima inners and S14 outers. this combo would be plenty long enough for your +25mm LCAs.
12-12-2013, 07:01 PM | #6062 |
i have pbm forged with PBM inners and SPL outers and have no issues. plenty of room.
Full 2014 build progress www.handicapmafia.wordpress.com |
12-12-2013, 07:13 PM | #6063 | |
The rears are 25mm, add the sub frame risers for an additional 10mm RC out back.
12-12-2013, 08:20 PM | #6064 |
So, to bring up a slightly older post... what's the difference between a "drop" knuckle and a corrected roll center knuckle?
Aren't you effectively doing the same thing by changing the distance between the spindle axis and the LCA ball joint?
'05 350Z Vortech @ 12 psi (SOLD ) '89 240SX 1UZ (turbo?) coupe |
12-12-2013, 08:47 PM | #6065 |
It is doing the same thing, but a drop knuckle lowers the car at the hubs by moving the hub upwards in the knuckle. A roll center correcting knuckle just drops the lower control arm mount, ride height will stay the same.
Some use a combo.
12-13-2013, 01:02 PM | #6066 | |
12-13-2013, 01:30 PM | #6067 | |
heres an updated pic. left is an s13 outer (same legth as an s14) and on the right is the 1990 maxima installed |
12-13-2013, 02:23 PM | #6068 | ||
12-13-2013, 02:30 PM | #6069 |
12-13-2013, 07:50 PM | #6070 |
I'm kinda new to this, but I have a question. Is having your rear arms as flat as possible the best for traction during drift?
Alex Bailey|Snatch'D Factory|(651)-333-7392|Instagram-snatchdfactory |
12-14-2013, 01:47 AM | #6072 | |
It is a LOT more complex than that. I'd recommend starting on the first page and doing a lot of reading. You'll get to see all my newb posts along the way .
12-14-2013, 12:52 PM | #6075 | |
12-17-2013, 11:57 AM | #6076 |
I have the tein inner and outer tie rods on my s13 and the added spacer they come with.
I've always wondered why they include a single spacer and say to put it on the passenger side... And I've always wondered if I could buy another spacer and put it on the driver side to get even more angle...
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
12-17-2013, 02:28 PM | #6077 |
i just installed kyb AGX struts on my s14. I have been riding on stock struts and megan springs for awhile and i went ahead and installed the fronts (put them on setting 3 of 4)
Today i went and put the REAR AGX's on my s14 and the setting are like 2-8 as where the fronts are only 1-4. That being said, I put the rears on setting 6. I am not used to the feel of driving with new struts, but i feel like i am understeering now when takin turns aggressively. By stiffening the rear, would that induce more oversteer or more understeer??? some one pm me please it would be appreciated.
95 S14 se RB25DET 348whp |
12-17-2013, 07:06 PM | #6078 | |
Oversteer.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
12-18-2013, 12:57 AM | #6079 | |
Bolt on angle spacers are usually recommended to be installed on the passenger side. I assume this is because of the way the gear teeth are cut on the steering rack, so that the pinion does not run out of teeth on the rack with the additional travel. |
12-19-2013, 02:12 PM | #6080 |
Looks like GKtech bolt on knuckle spacers are out:
https://www.facebook.com/gktech/posts/610878858961035?ref=notif¬if_t=like R chassis knuckles are also on 20 pair beta testing https://www.facebook.com/photo.php?fbid=610871455628442&set=a.1389000894922 50.23032.133362883379304&type=1&relevant_count=1 |
12-20-2013, 10:27 AM | #6082 |
12-20-2013, 12:49 PM | #6084 |
That's going to bang out a lot of angle if you can set the caster low enough so it doesn't overcenter! Unless your rack is moved forward, then you'll be good to go.
12-20-2013, 01:20 PM | #6085 |
Im kind of hesitant to move the rack forward because I really didnt get the knuckes for the angle aspect. I really liked the other benifits of them. Plus my car is slow and any more angle will slow it down too much hahah. Im going to have JSP add bump stops for me after I get the car together. He didnt want to add one and have it be hitting the tierod in an awkward spot.
12-20-2013, 10:19 PM | #6086 |
S13/180sx 40mm roll center correction kit - Limited production batch - ETA late January Seem to be on backorder already... * I just ordered mine, and it says ETA late January.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers Last edited by Black R; 12-21-2013 at 07:48 AM.. |
12-21-2013, 12:05 AM | #6087 | |
12-21-2013, 11:37 AM | #6088 |
^^Definitely, meant to say we didn't want to hit the tie rod at all.
I did just get the Pbm inners but I guess I'll pick up the eccentric kit too. Even though with my power I won't be able to utilize the angle while driving |
12-21-2013, 07:42 PM | #6089 |
There really are no downsides to moving the rack forward. Nor is there anything wrong with having more angle than you can use. It may come in handy when navigating into a tight parking space.
12-22-2013, 04:52 PM | #6090 | |
I have a question with the GKTech roll center correction kit, would I need to run extended tie rod ends? |
